Old 02-11-2005, 01:22 AM   #1
sactoC10
71 DELUX
sactoC10's Avatar
Distributor drop in, Top Dead Center?
OK, need to drop in HEI this weekend and I'm not sure about the TOP DEAD CENTER part of the install. What's the deal? Then also, anyone have the firing order in case I screw up the order when taking out the old plug wires?
Thank you very much.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 02-11-2005, 01:29 AM   #2
70c10swb
no brain no headache
70c10swb's Avatar
the #1 piston has to be at the top of the stroke on the compression stroke i belive
i dont have the fireing order on me right now
HTH
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 02-11-2005, 01:30 AM   #3
sdkid
18436572
sdkid is offline   Reply With Quote
Old 02-11-2005, 01:34 AM   #4
bigjimzlll
bigjimzlll's Avatar
pull # 1 plug...stick a piece of dampened paper towel in the plug hole. turn crank slowly until the paper towel "pops" out. then turn the crank until the damper points to 10 degrees BTDC. Install dizzy so the rotor points to the number 1 spark plug wire terminal.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-11-2005, 01:45 AM   #5
sactoC10
71 DELUX
sactoC10's Avatar
Ya'all make it sound so simple...but you have no idea how clueless I am. And yes, I do feel like a fool admitting it! Still don't "see" exactly what to do in my mind. I do understand bigjimz wet paper towel procedure, but is that firing order starting at the front passenger side, that plug #1?
Sorry, but GREEN I am. Dad sold cars, hated them and never wanted to touch them when home. No shop classes, just sort of learning as I go!
2003 FORD Escape
1998 Honda VTR1000
Old 02-11-2005, 01:51 AM   #6
70c10swb
70c10swb's Avatar
1. No you are NOT a fool, we all had to learn and we learn by asking questions and doing
2. the #1 cylinder is front driverside
1996 GMC Sierra z71
Old 02-11-2005, 02:01 AM   #7
sactoC10
71 DELUX
sactoC10's Avatar
Thanks, that's encouraging... By the way 70c10swb, I was born on the cape... Hyannis, MA. Still wondering why it doesn't seem to be a consistent concern, the TDC thing. Some instructions mention it, other don't!
2003 FORD Escape
1998 Honda VTR1000
Old 02-11-2005, 02:05 AM   #8
bigjimzlll
bigjimzlll's Avatar
it goes 1357 drivers side and 2468 passenger side. so you would start with the number one plug then the next hole clockwise goes to the #8 plug..then the next hole goes to #4 and so on
18436572
Anderson,CA
Old 02-11-2005, 02:17 AM   #9
70c10swb
70c10swb's Avatar
cool im from bourne
the TDC is just the easyist way i guess, its the only way i know
1996 GMC Sierra z71
Old 02-11-2005, 02:37 AM   #10
Johnny05
Johnny05's Avatar
If you still have the stock intake the firing order and cylinder location(18436572) information is cast into it. Look at the end of each of the intake runners and you'll notice the numbers. The firing order is cast into the intake as well just in front of the carb. If your standing in front of the truck #1 is at the right front. The right side is the odd bank 1357 the left side is the even bank 2468.
If you haven't changed/pulled anything yet you should be able to drop the HEI directly into the same location as the original setup.
Johnny05 is offline   Reply With Quote
Old 02-11-2005, 09:02 AM   #11
Tynee
I miss this truck.
Tynee's Avatar
Ask me how I know that you should be very choosy in your choice of helpers if you decide to use the "bump the starter method" to get to TDC. Some help will not know when the key is on or off, getting you shocked. Other help will think its amusing that you are now skittish under the hood, and will honk the horn while you're under there just for fun.
Also, if you're using this method, make sure the fuel line is attached to the carb or otherwise blocked. Again, ask me how I know.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-11-2005, 10:54 AM   #12
sactoC10
71 DELUX
sactoC10's Avatar
Gee Tynee, how do you know? Part of me thinks I ought to just pull the old one, put in the new one and just see if it works out OK... If I can get the plug wires this afternoon, probably be doing this tonight. Again, thanks.
2003 FORD Escape
1998 Honda VTR1000
Old 02-11-2005, 12:19 PM   #13
junkyardjohn
junkyardjohn's Avatar
YOU CAN DO THAT TOO. PULL THE CAP & MARK THE DIRECTION THE ROTOR IS POINTING WITH A MAJIC MARKER, ON THE FIREWALL OR VALVE COVER . PUT IT BACK IN EXACKLY IN THE SAME DIRECTION. JUST REMEMBER THAT THE GEAR ON THE DIST. IS A HELIX GEAR & WILL TURN SLIGHTLY IN THE LAST INCH OR SO OF INSTALLATION. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-11-2005, 12:52 PM   #14
Nima
Blue 67
I feel stupid to say anything infront of all these experienced people. I had todrop my dist when I changed my intake too. Great people on this board give me different ways of finding TDC. One of them which worked well for me, was using a cloth hanger or something similar. I inserted in #1 and then I rotated the engine manually until the hager stopped coming up (just have to becarefull that hanger doesn't get cut in there). I repeated few times to be differentiate between the compression and exhaust TDC. (other people please correct me if I am confused). Anyways, it worked well. If I could do it, anybodyelse can do it.
Good luck.
Nima is offline   Reply With Quote
Old 02-11-2005, 01:46 PM   #15
avejoe
Custer had a plan too.
avejoe's Avatar
Oh come on! Just drop it in and go. You have a 1 in 16 chance of getting it right.
"So, do you feel lucky?"
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-11-2005, 01:57 PM   #16
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
If you haven't turned the motor while the dizzy has been out, you don't need to find aTDC. Just Put it in where you had it.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 02-11-2005, 02:03 PM   #17
Zonaman
Zonaman's Avatar
[QUOTE=sactoC10]Ya'all make it sound so simple...but you have no idea how clueless I am.
Hey, if you don't do it every day you tend to need to ask. Good on you! Which reminds me, This is a job that can be helped along with one of those remote starter buttons. Which terminal on the starter do you hook those up to?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 02-11-2005, 02:19 PM   #18
mrein3
mrein3's Avatar
Junkyardjohn beat me to it.
If you are swapping distributors you don't need to know nothing about where the engine is.
Just draw a circle on a piece of paper, take the distributor cap off, mark a pointer on your paper showing where the rotor is pointing, pull the old distributor, and drop in the new one pointing in the same direction.
If there is gonna be a few days inbetween tape your "map" to the firewall so you don't lose it (and you remember which way is "north").
The only time I've had to worry about where TDC is is when I've done a timing chain and/or cam and/or dropped a distributor in a new rebuild. In all of those cases I just make sure I leave it at TDC when I have the timing chain cover off then if I rotate it I just make sure I keep track of whether I'm on #6 at the timing mark or at #1.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-11-2005, 04:39 PM   #19
sactoC10
71 DELUX
sactoC10's Avatar
Like this answer ALOT!
2003 FORD Escape
1998 Honda VTR1000
Old 02-11-2005, 06:55 PM   #20
Kid
Kid's Avatar
another way to find TDC is to remove the spark plug from #1 cylinder and hold your thumb or finger over the hole. Then bump the starter untill compressed air pushes on your finger. That means you are on the compression stroke. Bump starter again until your timing mark on damper is aligned at TDC on pointer, being carefull to not over shoot your mark, If you do no big deal, just do over. Then drop in your distributer.
Kid is offline   Reply With Quote
Old 02-11-2005, 10:15 PM   #21
gmc67swb
gmc67swb's Avatar
Also once dropped, you may have to keep pressure down on the distributor while turning the motor until the distributor drops into the oil pump.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-12-2005, 01:49 AM   #22
4x4Poet
Originally Posted by Nima
I feel stupid to say anything infront of all these experienced people....
Originally Posted by mrein3
...Just draw a circle on a piece of paper, take the distributor cap off, mark a pointer on your paper showing where the rotor is pointing, pull the old distributor, and drop in the new one pointing in the same direction.
If there is gonna be a few days inbetween tape your "map" to the firewall so you don't lose it (and you remember which way is "north")....
When I pulled the dizzy from my TravelAll's 392 to install a Pertronix Ignitor, I wrote myself a note to record the rotor's position. Lost it because I didn't post it prominently as mrein3 suggests. Had to visit the Binder Bulletin to learn how to find TDC (cyl#8).
Good advice, here.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-12-2005, 02:14 AM   #23
Solver
Solver's Avatar
I always seem to have to take a long screwdriver and set the oil pump shaft so that distributor will drop down where I want it to.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 02-12-2005, 09:14 AM   #24
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I don't bump the starter, I just stick my finger in the hole and turn the engine over by turning the fan with my other hand. Wear a glove.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-12-2005, 09:42 AM   #25
modifiedGMC
The first time I ever had to deal with firing order/ timing was when I was sixteen. I had a 69 chevelle with an aluminum intake that had no firing order cast to it. There was a stock one in the shed and me and a buddy went to the shed and looked at the intake. I remembered 1843 and he remembered 6572 and noticed the number 1 on the intake runner. Then went back to the chevelle and put our plug wires on. I always get number one up on top of the compression stroke, line up the crank timing marks on the damper and position the distributor in the intake where it sets, then turn the rotor so it will point straight at or slightly past the carb and drop it in. If it doesn't line up with oil pump and go all way down, then I just simply hold down on the distributor and bump the starter over till it does. then I double check myself and get number one back up and check position of the rotor. dist installed! then wire up the plug wires 18436572 starting with driver side front cylinder (even number side) and proceeding clock wise on the distributor starting the terminal Imarked as number one.
P.S. Tx fire fighter, that only works if you DON"T have a clutch type fan like I do.
modifiedGMC is offline   Reply With Quote
