Old 02-12-2005, 10:39 PM   #1
68c10owner
68c10owner's Avatar
how to remove ignition switch without a key
I don`t have a key for my new project. How can I remove the ignition switch to replace it? Thanks.
Anthony
68c10owner is offline   Reply With Quote
Old 02-12-2005, 11:04 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=123712
Old 02-12-2005, 11:09 PM   #3
jewels.
jewels.'s Avatar
http://67-72chevytrucks.com/vboard/s...ylinder+remove
damn, andy, i think you beat me to it!!!
stop already!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 02-13-2005, 01:04 AM   #4
Longhorn Man
yep..by 5 min too!
And to think...I don't know how to type, and I still beat you to it.
Old 02-13-2005, 02:06 AM   #5
68c10owner
68c10owner's Avatar
Thanks for the link. I`m not worried about trying to start it with another switch right now, I just need to get the old one out so I can replace it with one that I have a key for. Would drilling it help any or would it just make it worse? Thanks.
Anthony
Old 02-13-2005, 02:11 AM   #6
cheyenne10
cheyenne10's Avatar
me too
Would like a highly probable way to get one out without damage to dash. Are metals inside lock hardened and drilling would be fruitless effort? Can locksmith get one out?
Bob
cheyenne10 is offline   Reply With Quote
Old 02-13-2005, 03:18 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I've had to drill a few out. It's not too hard but I used 4-5 different size bits just to make sure that the drill didn't jump aroound and hit the dash...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-13-2005, 10:01 AM   #8
MOTHERTRUCKERS
We drill them out with a 3/8 bit.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-14-2005, 04:42 AM   #9
jimfulco
Try every old Chevy key you can borrow or steal. If it goes in all the way, jiggle it around while putting counter-clockwise pressure on it. You might get lucky.
jimfulco is offline   Reply With Quote
Old 02-14-2005, 07:48 AM   #10
RON WOODGEARD
Resident Young Old Dude !
I have a can of old keys for just this thing.. Old Chevy keys seem to be able to work on other Chevy vehicles.. Do as Jim says,, Insert and jiggle, up and down while turning easily...( But not too..)
RON WOODGEARD is offline   Reply With Quote
Old 02-14-2005, 10:14 AM   #11
StingRay
StingRay's Avatar
If you don't mind wrecking the bezel around the ignition cylinder just pick an appropriate size if hole saw that fits inside the bezel and use it without the pilot bit. The bezel will center it for you and hole saw away. The only thing that will actually get damaged is the bezel itself and it takes about 30 seconds to get the job done.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 02-14-2005, 12:39 PM   #12
68c10owner
68c10owner's Avatar
Do you know what size hole saw to use? This sounds like the easiest and quickest way. I don`t mind getting a new bezel.
Anthony
Old 02-14-2005, 01:01 PM   #13
gonebad2
Merciless Butcher
gonebad2's Avatar
If you are drilling it out, don't forget to remove the wiring harness before you do it.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 02-14-2005, 01:05 PM   #14
Blue Beard
Blue Beard's Avatar
The chevrolet lock is what's called a Sidebar Wafer lock....hard to pick too.
Not only do the keys line up the tumblers....but doing so allows a side bar to fall in place with the tumblers. Wish I could find the pic in my books for this...
Use to do locksmith work part time and learned alot about these.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-14-2005, 02:16 PM   #15
StingRay
StingRay's Avatar
Can't remember off hand but just the size that slips down inside with a little to spare on each side. I just grabbed what ever I had that was close.
Canada
