12-08-2004, 02:56 AM | #1 |
Disk brake spindles
Hi everyone,
I was wondering if there was any GM disk brake spindles that would bolt on to my 67 1/2 cst. I am currently running all around drums and would like to upgrade to a power disk system. thanks, matt
Truck #1: 1972 Chevrolet K20 Cheyenne Custom Camper SB400, TH400, NP205 Truck #2 1967 Chevrolet C10 Custom Sport Truck 327 small journal, TH400 |
12-08-2004, 03:03 AM | #2 |
71-72 and 73-79 will work if you change the tierod ends and ball joints. one guy even wrote up an 88 disc brake conversion
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
12-08-2004, 03:04 AM | #3 |
71-72 spindles will work and 73-87 with diffrent ball joints.all five lug wheel pattern no 6 lug discs for 2wds.i have seen some after market 6 lug ones at Scotts Super Trucks in alberta canada
12-08-2004, 10:08 AM | #4 |
Watch out for your cornhole !
Whether he uses the 71-72 spindles or the 73-87 spindles, he's going to have to change his balljoints no matter what.
12-08-2004, 01:17 PM | #5 |
I have a set of 71' stock DB spindals available if you need???
Alex 1971 Lil' Red 350 SBC 700R4 |
12-09-2004, 06:12 PM | #6 |
well maybe i can try that, but its kinda a bummer since i have 6 lug drums. maybe I will do that and convert the rear to 5 lug if that is possible.
12-09-2004, 10:40 PM | #7 |
I just switch 6 lug to five on my 70 in rear.I got the axles from a 71 suburban and they where exact length of my 70 and fit perfect.Will do some work on front soon to put disc up front with 5 lug.Not sure what it will take but I see no reason not to try front parts from same 71 suburban.The more you work on these the more you learn and its better then TV.
12-10-2004, 12:25 PM | #8 |
the rear axel is shorter on the 67-69 and some of the 70 6 lug then the 71-72 5 lug. The 5 lugs will work in the 6 lug houseing but you will have to space the backing plates out so the brakes will go inside the drums. You can find 72 rearends pretty cheap
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi Last edited by flip66; 12-10-2004 at 12:28 PM. |
02-14-2005, 12:25 AM | #9 | |
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
02-14-2005, 12:46 AM | #10 | |
GMC-2500 , with front disc brakes and the truck is 6-lugs.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
02-14-2005, 12:52 AM | #11 | |
02-14-2005, 01:06 AM | #12 | |
02-14-2005, 01:14 AM | #13 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
