MI '69
![]() Join Date: Oct 2004
Adjustable Panhard or Super Trackbar Kit???
I bought some Airlift 2600's from suicide over the winter, ive finally gotten around to mounting them and realized that i want to get things all aligned properly before i drill into my frame to mount the things. So, i need to get a different panhard to correct for the drop. Problem is, ECE sells both a adjustable panhard for dropps 4" or less, and a super track bar kit for drops greater then 4". I'm not sure which one to purchase. I know that when totally deflated, i would probably want the super track bar, but when im driving around inflated, will it give me any trouble?
oh, btw, i fabbed up som blocks for the bags to sit on, so that adds about 1.5 inches to the bags. that would factor into the total deflated height and the total inflated height..... any thoughts or ideas????? one more thing.... suicide lists those bags as having a max height of 9.5" and a designed ride height of 8". they also list them as having a 3" or so deflated height. i won't want to max them out, and i probably wont want to bottom them out either. so lets say i want to go from probably 8.5" @ high, and 3.5" at low, that gives me a range of 5"...... so the super track bar seems to make sense, BUT, again the problem is, what will happen when i inflate them to 8.5" while im driving around...... the drop then is inside the adjustable panhard bar range....
1967 Chevy (Project Frankenstein) 1973 K5 Blazer Last edited by cysko9; 02-07-2005 at 02:23 PM. |
#2 | |||
MI '69
sounds pretty straight forward, but i just want to make sure....
1) adjustable panhard will not let me go to min ride height... 2) super track bar will give me problems at max ride height... and you (scoti) are saying that panhard will give me most flexibility with heights... i just want what will give me the best of both worlds (high and low)... although it kindof looks like that may be impossible....
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
Head Peon
![]() Join Date: Dec 1999
No matter how much drop you have a longer panhard bar will give you less side to side movement period...optimum panhard bar setup is level at ride height. Scoti does make a point you have to take tire/rim combo into consideration, the tighter the combo, the less side to side movement is allowable. Trust me, with 5" drop springs on the back of my burb the side to side movement was obnoxious with the stock length panhard bar when I hit a good size bump...and you know as well as I do how shi**y Michigan roads can get. Check your pm's...I'll let you know what's up as soon as I get word...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
#5 | ||
For my set-up, since I don't adjust the height very much, the adj panhard bar worked fine. Since your plan calls for extreme extended/compressed heights, the super track-bar is the way to go.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-08-2005 at 06:17 PM. |
MI '69
thanks much fella's. Looks like its going to be the super track bar... unless your plans work out shev.... i'll wait and see....
thanks again.
C10 Club Tennessee
Not to but in guys, but are you saying that if I have a 6 inch drop in the rear that an adjustable panhard bar won't help me?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#8 | |
If the ride height is static, or your air rides drop doesn't vary much in height, the shorter bar works fine.
If you want the best of both worlds check out a Watts linkage setup.
Rest in Peace Ed. Thanks for all the good times. |
MI '69
where should i look for the Watts linkage?
Take a look at the post on the next page.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
MI '69
im pretty sure im missunderstanding you when you say look at the next page....
cuz im only seeing one.????? next post?
I believe neonlarry was referring to this post.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
MI '69
thanks, wow, looks liek alot of work... perhaps i'll just stick to the super track bar.....
#15 |
Too Many Clubs Club
I've got the ECE super track bar, and here's why...
The ECE bar is 35.5 inches long; longer bar means less side to side movement. How much movement? Let's look at the geometry involved. The attached diagram I threw together should help explain. With the added suspension travel afforded by air bags, side to side movement can get out of hand. Take the Air Lift bags that I'm using. Their minimum height is 2.8 inches and their maximum height is 9.5 inches. That equates to a 6.7 inch range of motion (stroke). In the top sketch, the bar is horizontal with the bags deflated. When the bags are filled to their maximum height, the side to side movement is .64 inches. This is just an example though. On our trucks when the bags are fully deflated the bar is angled up to the passenger side. In the real world, the geometry is more like the bottom sketch. The bar is horizontal at ride height, and travels up and down past horizontal as the suspension moves. In this scenario, the side to side movement is lessened even more as the shift is "split". Get the ECE super track bar. If your clearances are so tight that .32" is critical, then look into a Watts set up.
How I installed my air bags... |
#16 |
MI '69
excelent. thats exactly what i was looking for. thanks.
