Old 02-15-2005, 03:20 PM   #1
farside847
farside847's Avatar
My oil gauge acts like my wife...
Always over-reacting....
When Im cruzing on the freeway it is pegged out way over to the right, but
when Im at idle it is only 1/4 of the way over (too low). I checked my oil
and it is fine. It even does this right after an oil change. Does this happen to
you? Think I need a new sender?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-15-2005, 03:22 PM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
I,ve heard an old engine-builders tale that says you need 10 lbs of pressure for every 1000 rpms. My buddy said that was a Smokey Yunick theory...... Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 02-15-2005, 03:24 PM   #3
greasemonkey
greasemonkey's Avatar
Sounds normal to me, I don't know the increments of pressure on the stock guage but 1/4 doesn't sound too low, it's probably 10-15 pounds at least, which should be okay. Mine used to always peg the stock guage too when the I ran the RPMs up.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-15-2005, 03:33 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
the standard guage is 60psi. The 1/4 mark would be 15psi at idle. More than enough pressure for a chevy engine. It sounds like you might have a high pressure oil pump in your engine. Not neccessarily a bad thing, but it will peg a 60psi guage. FYI...80psi guages were available on the larger trucks.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-15-2005, 04:01 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The 10 psi per 1000 rpm thing is an official GM guideline. That's how they determine warranty claim validity.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
