Old 07-17-2002, 01:41 AM   #1
Low69CST
Need help quick, truck weight
Short fleetside, small block, air conditioning, 4 core, power steering. power brakes. blazer tank. I'm guessing 3800-3900lbs. But i need some verification. Going to the transmission shop tomorrow evening.
Thanks guys
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-17-2002, 07:13 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
7 pucks at any Pilot truck stop...and there will be no guessing involved. You can even get the front to back weight.
Old 07-17-2002, 08:31 AM   #3
toms68cst
toms68cst's Avatar
Stock weight of a 68 SWB Fleetside V8 is 3946 lbs. You might add a little for the PS and AC. 100 lbs or so?
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 07-17-2002, 09:06 AM   #4
Woody
Low,
My truck has the same specs as yours (except I still have the tank in the cab) and it wieghs in at 3850 plus my fat butt. This was at the rock quarry.
PS: Thought I had the 3:1 ratio for the cover charge but Mom and the Mother-in-law couldn't make it after all.
Woody is offline   Reply With Quote
Old 07-17-2002, 10:50 AM   #5
Low69CST
Thanks guys. It wouldn't do me much good to haul it to a scale. I have no tranny or engine in the frame. guess I need to add "in progress" to the signature. Woody if yours is 3850, i'm guessing mine is about 3950-4000. Forgot to mention I have a rear end that weighs atleast 40lbs more than a 12 bolt, added on camaro sway bar, $500 bucks worth of Dynamat Xtreme in the cab, 700R4, big box with subs and amps. Thanks for the help guys. Anybody know how big of a factor weight is when picking a torque converter? Is it as big as knowing what cam specs are?
Old 07-17-2002, 10:51 AM   #6
Low69CST
almost forgot
Woody-
Only in Kentucky does a guy bring his mom to a keg party!
Old 07-17-2002, 08:12 PM   #7
Longhorn Man
Weight, tire size, tranny type, gears, and torque curve all have a drastic effect on a 'verter.
