Old 02-12-2005, 10:18 AM   #1
Tully
help with year of K20 chassis
I have a 3/4 ton 4x4 chassis under a 71 GMC 4x2 body. I am not sure of the year of the chassis, it has disc brakes, hub size for rims are 4 3/4" (see pictures), and the front leafs are 3" wide.
Tully is offline   Reply With Quote
Old 02-12-2005, 12:55 PM   #2
Mudder
Mudder's Avatar
Sounds like a newer frame like mine but those that really know will help ya out.
Mudder is offline   Reply With Quote
Old 02-12-2005, 01:33 PM   #3
Mudder
Mudder's Avatar
Ok Tulley after giving you crap over on the other board for douple posting hehe, few questions about your frame. Does it have a sway bar? Are there extra holes where the cab mounts? I have a 77 chassis and it has 3 inch wide springs.
Old 02-12-2005, 02:25 PM   #4
Rod
3inch wide leafs I believe are 73 up.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-12-2005, 04:50 PM   #5
Tully
Mudder, there are no extra holes in the frame but I have come to the conclusion that the PO put 73 up front springs under it. The brackets and shackles are bolted on. The rear shock and spring mounts are riveted on so they didn't try shortening a 73 up chassis. I started sanding through the caked rust to try and find the frame number I will let you know what I find.
Old 02-12-2005, 05:50 PM   #6
Blazer1970
Blazer1970's Avatar
Get the BOM number off the front Dana 44. It will tell you the original year and application.
Blazer1970 is offline   Reply With Quote
Old 02-12-2005, 08:15 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Are the leaves 3" over the whole length of the spring? Stock for my 70 and 71 were 3" wide at each end and 2.5" in the center. 2nd, on the 3/4 tons I believe the internal style hub showed up in 76 or 77, before that they were all external style. Measure the length of the front springs, 73 and up springs are 3" longer than the 72 and earlier springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-12-2005, 09:14 PM   #8
Tully
Tim, the numbers I found on the dana 44 are C-31256 287 44 5F
Jim, you are right the springs are 3'' at both ends and 21/2" in the middle. I never noticed that before. With weight on it they measure 43 3/4", hole center to hole center.
Old 02-13-2005, 05:05 PM   #9
Blazer1970
Blazer1970's Avatar
The BOM number is a 6 digit number that will be stamped on the front of the axle tube to the right of the pumpkin when looking under the front of the truck. You will likely have to sand some rust off the tube to reveal the numbers.
Old 02-13-2005, 07:52 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Tully, those are pre 73 springs. Same length as both my trucks. 73 and up are 46" long. I say your axle is a late 70s and your frame is pre 73 maybe even a converted 2wd truck.
Old 02-13-2005, 08:55 PM   #11
Tully
Tim, I sanded down and found 10 20 1A4 603351 3
Jim, I think you just nailed it. Its a 2wd body and they put the front differential under it, that's why it's bolted. To do this they had to lift the truck because of the low hump. ( I put a high hump in and dropped it back down). The only other thing that puzzles me is the large rims needed. The only rims I have found are Ford, chrysler and some white spokes that will fit. In fact the chrysler ones only work up front.
Old 02-13-2005, 09:41 PM   #12
1969 GMC
1969 GMC's Avatar
603351
DANA 44 FRONT
Year 1972
Make CHEVY
Model K5 Blazer, K10 1/2 Ton Pickup & Suburban & Panel Truck
Number of axle splines: 30 FULL
hope it helps!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-15-2005, 12:34 PM   #13
poff
The VIN number should be stamped in the frame somewhere.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 02-15-2005, 09:09 PM   #14
Tully
I looked for the Vin # on top of the frame rail by the power steering pump and nothing there. Where else should I look?
Old 02-16-2005, 08:54 PM   #15
Rod
Its under the cab also....but can't really be seen without removing the cab.
If" 1969 GMC "found info on dating your front axle..it could be that some one just swapped out the locking hub style to newer version locking hubs, and the hub its self. It can be done and might of had to have been done that way as parts for the 70-72 style 3/4 ton locking hubs are hard to find.
Old 02-16-2005, 10:02 PM   #16
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
If its a converted 2wd chassis, a hole would have to be drilled in the frame for the rear shackle to mount (on the front diff.)
Here.........
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-18-2005, 09:56 AM   #17
Tully
Denny, yes it looks like the rear shackles were added, they cobbled some steel plates on the outside of the frame that covers up the hole they cut.
