Old 02-18-2005, 06:17 PM   #1
Tom
driving is in my blood
Tom's Avatar
Changed cab bushings, now I cant move the gear selector
WTF is going on here? All I did was change the cab bushings, now the gear selector lever wont budge. I got under the truck and the linkage is fine, no bends, breaks or binding anywhere. Why is my truck doing this?
On another note, the rear drivers side of the cab is still lower then everything else so my truck looks screwed up still. Im guessing this means bent frame?
Old 02-18-2005, 08:06 PM   #2
60-66 Nut
Professional Beer Tester
When you lifted the cab to change the bushings, did you unhook the shift linkage first? If not, it may have tried to turn backwards when you let the cab down. You might try unhooking it and make sure it's trying to go the right way. Hope that helps, good luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 02-18-2005, 08:33 PM   #3
Tom
Tom's Avatar
I ended up having to drop the tranny pan as it turned out to be internal. A few good whacks with the plastic end of a screwdriver got it working good again. Freakin automatics....
