Old 02-18-2005, 12:56 AM   #1
skokie
skokie's Avatar
Pertronix Points Kit
Has anyone used that pertronix kit to change your points distributor over to well I guess a hei? Its called the ignitor II ignition. What are the pros and cons?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-18-2005, 12:59 AM   #2
mr402
I have one of the original versions of the ignitor on my 62 Chev 235. It's been on a few years and I've never had a problem.
mr402 is offline   Reply With Quote
Old 02-18-2005, 01:00 AM   #3
skokie
skokie's Avatar
How did you install it? What's involved?
68 build thread
Old 02-18-2005, 01:44 AM   #4
4x4Poet
The original Pertronix Ignitor can melt if the key is left on for a long time without the engine running. If you go Pertronix, be sure to only use the Ignitor II with a coil that matches the Ignitor II's ohm needs, whether the Flamethrower II or another brand coil with the same characteristics. The Ignitor II has the advantage over the original Ignitor by having a circuit that senses when the ignition key is left on to prevent the Ignitor II from melting. It's written about on Pertronix's site.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-18-2005, 01:58 AM   #5
skokie
skokie's Avatar
Thanks for the info. Here is a article from the web about it.
http://www.rodandcustommagazine.com/techarticles/73738/
68 build thread
Old 02-18-2005, 02:37 AM   #6
4x4Poet
Pretty good article. The summit cap they used is an interesting option for 69-74 dizzys. It's only draw back would be the non-stock wires issue. 67-72 users with Rams Horn manifolds would probably be restricted to using 75-6 Vette wires. Less chance of finding them at a parts store. But then how often would they need wires that quick? Could carry used HEI wires for emergencies.
I'll be installing the Ignitor II and Flamethrower II on my K10's 350 that I'm rebuilding. I'm considering adding Pertronix's Second Strike box, but my budget should stop me from taking that step until later this year.
Old 02-18-2005, 03:03 AM   #7
HeavyD
HeavyD's Avatar
I used ignitor on a few vehicles..good investment IMO
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 02-18-2005, 03:04 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hey guys that article is just what I've been looking for to give me the distributer cap for using HEI wires on my pertronix system on my vette.Now all I need is some wamer weather to work in. Garage is not heated yet.
4x4 poet thanks for the help on thread linking. I think I've got it down.
Vettevet-old but still learning
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-18-2005, 03:33 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have the IgnitorII/Flamethrower II stuff on my shelf waiting for my 292 to get done breaking in. I have a NOS Accell L6 single-points distributer to mount it on. Had heard that the Ignitor II required an ignition-on 12 volt source, preferably 10 or 12 gauge wire, because the yellow wire (to the coil)set-up drops to 7 volts once it heats up. The article makes it sound optional.
Old 02-18-2005, 09:42 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have one and this unit from GMC Pauls http://www.gmcpauls.com/pictures/Bre...20&%20Info.htm
It only uses one wire vice a seperate power wire.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-18-2005, 12:08 PM   #11
farside847
farside847's Avatar
I just had my 307 rebuilt and had one put in at the same time. 700 miles with no problems. Im looking forward to not having to change the points.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-18-2005, 04:31 PM   #12
71-longbed
Its Magically Delicious
71-longbed's Avatar
i've been running a Igniter I with a stock 12v coil for 2 years .. zero problems ... if you set the key at acc instead of ON you'll have no problems ... One thing i have heard about the first igniter is that is takes a few seconds to charge once you click it to "ON" ... i leave it there for about 3 seconds and then turn the engine over...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 02-18-2005, 07:28 PM   #13
skokie
skokie's Avatar
Also forgot to ask this one. Does anyone have a factory tac on the pertronics unit? Whats the setup for that?
68 build thread
Old 02-18-2005, 11:13 PM   #14
mr402
Skokie, Great article. I found swapping the unit in easier than installing points. Since my 62 is a restored vehicle I liked the idea of it being pretty much concealed. There is an extra wire coming out of the dist. but I placed both wires in black shrink tube to make it less obvious. Looks like the I2 is even better. Maybe I'll upgrade this summer.
Old 02-19-2005, 01:53 AM   #15
skokie
skokie's Avatar
I got my birthday coming up so I will ask for it from the misses
68 build thread
Old 02-19-2005, 05:59 AM   #16
4x4Poet
JIMs70GMC, that is a great product of which I had yet to hear. I didn't know M&H made ignition upgrade stuff. Good education on coils, too. Thanks.
Originally Posted by '68OrangeSunshine
...Had heard that the Ignitor II required an ignition-on 12 volt source, preferably 10 or 12 gauge wire, because the yellow wire (to the coil)set-up drops to 7 volts once it heats up. The article makes it sound optional.
I thought the article said users would get worse performance on the ballest resistor wire vs. a regular wire from an ignition/starter on source. Not exactly optional. I wonder what my Ignitor II instructions say??
