Old 02-18-2005, 12:21 AM   #1
ronthet
boby side moulding
Ok, 1968 Chevy CST, LWB, 3 on the tree. I have all my moulding off and need to clean it up to shine. Is this stainless, chrome or what. I have some stuff I used on my chrome bumper I got at Pep Boys in a silver can. Looks like cotton and you just peel it out and rub it on then buff. It worked pretty good on chrome, but not so good on my moulding. A new paint job soon, so I need to restore my moulding, or weld up everything and forget the moulding.
Also including all the chevy bowtie etc. Any suggestion on what to use for cleaning and geeting a shine back????
ronthet is offline   Reply With Quote
Old 02-18-2005, 12:36 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
arnt the side moldings aluminum? try some polish, i have used stuff called hollywoods with good results on wheels, but couldnt tell you bout side moldings, i dont have any
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-18-2005, 07:28 AM   #3
Terry Peerson
The Body Side Mouldings are Anodized Aluminum. Regular type polishing really won't do much for it. To do it right, you will have to remove the anodizing. EZ-OFF oven cleaner will do it. Then you can either polish it either by hand or with a buffing wheel. After that, you can either a) Have the piece re-anodized, b) Shoot some kind of Clear-Coating on it, or c) re-polish whenever it seems to be getting dull. You can perform the anodizing process yourself, but it involves some very dangerous chemicals and electricity. If you do attempt to "home-anodize", take every precaution seriously and ABSOLUTELY wear chemical-resistant goggles!
BTW: One thing that interests me is the fact that you can also "Color-Anodize". Simply by adding certain dyes to the anodizing solution, you can protect your aluminum parts in custom colors. Some even look kind of like chrome.
TP
Terry Peerson is offline   Reply With Quote
Old 02-18-2005, 04:32 PM   #4
ronthet
thanks, I am not familiar wit Anodizing so I guess I need to investigate.
Old 02-18-2005, 07:46 PM   #5
8door
Not too old to learn
Question
[QUOTE=Terry Peerson] If you do attempt to "home-anodize", take every precaution seriously and ABSOLUTELY wear chemical-resistant goggles!
How you do that?I sthere a kit like powder coating?
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 02-19-2005, 09:30 AM   #6
Terry Peerson
The first place that I would investigate would be Eastwood. I know they have home powdercoating kits available. They might also have anodizing, kits too. If you do a "GOOGLE" search for Aluminum Anodizing, you will find several sites that offer some instructions for home anodizing. It looks like a fairly simple process. But, it does involve some very toxic and dangerous chemicals along with running electricity to the solution. I'm pretty sure that you have to: 1. Remove all current anodizing from the piece. 2. Polish part to "Mirror-Like" finish. 3. Prepare Caustic solution tank. 4. Immerse part into solution. 5. Soak part in solution (I can't remember how long). Apparently, the anodizing solution has to have electricity to work. If I understand this correctly, the process causes the aluminum to form an extremely durable coating that is actually a thin layer of corrosion. This layer is very resistant to scratching (within reason) and further corrosion (which is the dry, white powdery stuff that forms on aluminum). I haven't tried this yet, myself. But it looks like a cool way to restore those aluminum parts that are not easy to find. Aluminum that is left un-anodized will begin to corrode immediately (it's similar to bare-steel rusting). You could just leave the part un-anodized after polishing, but you would have to periodically re-polish the part to remove the corrosion that has formed. Painting a clear paint coating will work...for awhile too.
T
