Old 02-20-2005, 07:59 PM   #1
gregbr
Senoir Member
gregbr's Avatar
hi/lo hump cabs
Which cab is installed on a factory 4wd truck....hi hump? If it is the hi hump, can a low hump cab be installed or modified to install without problems? Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 02-20-2005, 08:03 PM   #2
vtblazer
vtblazer's Avatar
Two option's.
Cut out the low hump and install a high hump or
install a body lift.
If you go the body lift route, you'll need to modify the low hump to accommodate the 4x4 shifter.
vtblazer is offline   Reply With Quote
Old 02-20-2005, 08:04 PM   #3
dtlilly
dtlilly's Avatar
4X4 trucks had a high hump. You can cut the low hump out, find the removable hump with the type holes you need and bolt it in. Another option you have is to install a body lift, so the tranny and t-case will fit under the cab.
dtlilly is offline   Reply With Quote
Old 02-20-2005, 08:19 PM   #4
Striker169
Car O'Holic
Striker169's Avatar
could someone show me pics of a hi and a lo hump?
Striker169 is offline   Reply With Quote
Old 02-20-2005, 09:40 PM   #5
gregbr
Senoir Member
gregbr's Avatar
Sounds OK, is the removable hump the hi hump or do both humps just bolt in?? I have another truck with a factory BB, I understand it will have the hi hump also, but I have never compared the two. Is the hi hump taller like it sounds? Thanks for the great info. Greg
Old 02-20-2005, 10:01 PM   #6
neonlarry
neonlarry's Avatar
Hi hump is taller and bolts in low hump is part of the floor i.e. one piece.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-20-2005, 10:25 PM   #7
gregbr
Senoir Member
gregbr's Avatar
Thanks neonlarry.
