Old 02-20-2005, 10:38 PM   #1
orangeuavol
GO VOLS!
orangeuavol's Avatar
antenna wire
where does the antenna wire go through to the inside?
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 02-20-2005, 10:50 PM   #2
pound41
Theres a hole behind the glove box that sits in the corner. stick your head in there and look towards the antenna. I don't really know if there was an actual whole in the design for it or some guy in the factory with a drill. I have seen them in different widths away from that corner, but in that general area. The hole is just enough to get the end through
pound41 is offline   Reply With Quote
Old 02-20-2005, 11:38 PM   #3
jhow66
jhow66's Avatar
This is on a 72 Blazer--there is a hole on driver side removable cowl the size of the ones on pickups and a hole (3/8") on pass side. Here is the catch--no hole in cab cowl to inside!
(orangeuavol's dad)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-20-2005, 11:57 PM   #4
Gee_Emm
Gee_Emm is offline   Reply With Quote
Old 02-21-2005, 12:14 AM   #5
jhow66
jhow66's Avatar
Thanks Gee Emm. If they came from factory with no radio would the hole still be there? This one has no hole.
Old 02-21-2005, 04:55 AM   #6
JimKshortstep4x4
Smile
If they did not have a radio, then the hole was not drilled. The hole is a nominal 5/8" to fit the factory grommet that is on the antenna wire.
When installing them sealing arond the grommet is recommended as they are a leak source.
Jim
Old 02-21-2005, 10:32 AM   #7
Gee_Emm
I don't believe my 69 had come with a radio but the hole was there just like any other truck. I think it is one of those whimsical factory things.
Old 02-21-2005, 11:05 AM   #8
JimKshortstep4x4
Smile
Gee Em,
There are plenty of those!
The trucks that I have seen without the hole don't have the speaker bracket holes drilled either. Could be a year thing or assembly practice.
Jim
Old 02-21-2005, 12:33 PM   #9
jhow66
jhow66's Avatar
Thanks fellows.
