Active Member
I am trying to retrofit a 72 power brake system (booster, master cylinder, prop. valve) to my 68 C-10. With the system installed, the brake master cylinder looks like it is leaning down too much. Will the 72 unit work on a 68?
Thanks in Advance! Sonny ![]() |
Resident Curmudgeon
![]() Join Date: Dec 1999
It should but if you still have drums front and rear you want to use the master cylinder and prop valve from the 68. As far as leaning, do you have pic?
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Active Member
I don't have a pic yet. I have front disc/drum rear(5-lug). The 72 I pulled the unit from had disc/drum setup I believe. I didn't look too hard. Plus the support brackets do not line up anywhere on mine. I do have a pretty agressive stance too. I will try and attach a picture in a few. I remember someone looking for the boot that goes on the firewall. I found a part number and I ordered one from the chevy place. I am supposed to get it tomorrow.
Resident Curmudgeon
If the unit you pulled is truely for a 72, the support bracket should line up with the 4 studs off the pedals coming thru the firewall. Direct bolt-on, zero issues.
#5 | |
Embrace the Redneck
i don't know about you guys but seeing a grown woman drivin a pickup of any size is very attractive to me. thanks sswj
'01 Camaro Son, you just can't get there from here... |
More Cowbell....
Yep. I added power to my drum/drum system. Moved the master forward, slid the booster in place and bolted her up. Ran the vacuum hose to the intake and BOOM...POWER BRAKES. Running fine for many months now.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Designated A-hole!
white, that's all I did. You don't even have to unhook the brake lines from the m/c. You will need to lengthen the brake sensor wire though (I just left mine disconnected.)
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Active Member
Here are some pics. You can see how much the booster/cylinder tilts down.
Try: http://www.heartofgeorgiaspeedway.com/truck.html Sonny ![]() ![]() ![]() ![]() Last edited by Sonny; 02-22-2005 at 04:09 PM. |
Active Member
The brackets I were talking about are the two extra brackets that angle down to the firewall. In my excitement to paint and install the brackets I didn't pay much attention to their exact orientation. The booster bracket bolted up nicely.
The LuvShack Garage
Looks Like Mine
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#11 | |
Resident Curmudgeon
Active Member
Now my question is which line goes where? Originally the front line went to the front brakes and the rear line went to the back. Do I still do this even though the bigger line going to the prop valve goes to the rear? I was planning to hook them up the same orientation: Front brake line to the bottom hole in the front of the valve and the rear brake line connecting to the back hole. FYI save the b-nuts from the donor truck's brake lines. Mine didnt match up and I have to go back tomorrow and get them.
Embrace the Redneck
the tilt has nothing to do with pressure, i wouldn't worry abou it .
and to the resopnse on the drmdrm master.......SWEET!!!! I can lower my standards and find a good one to get . thanks guys! sswj
#14 | |
Resident Curmudgeon
#15 |
Active Member
Both of the reservoirs are the same size. The back reservoir has the larger line coming from it. I will try and hook up the front brake line to the larger aft port on the prop. valve and see what happens...
Thanks for all of the help! Sonny |
