Old 02-24-2005, 12:37 PM   #1
72GMC51
72GMC51
72GMC51's Avatar
Lower radiator hose
Any one have the GM Performance parts serpintine system (or any stock GM serp system) if you do what lower Rad hose do you run, the stock one just won't make the curve and I tring to stay away from a flex hose. My truck is a 1972 GMC 1/2t 2wd 350 Auto a/c
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 02-24-2005, 01:25 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
I assume you're running the long pump. I don't have the serp, but was able to make a Dayco 70664 work with the long pump.
http://207.44.196.117/vboard/showthread.php3?t=138379
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-24-2005, 02:39 PM   #3
72GMC51
72GMC51
72GMC51's Avatar
The problem is the alum bracket for the a/c pump and air pump, cant make the corner around it and the frame, it is alot lower.
Old 02-24-2005, 03:52 PM   #4
67chevemall
67chevemall's Avatar
Is the belt rubbing on the hose in that pic above?
Maybe you'll have to make a steel extension or such?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-24-2005, 09:35 PM   #5
72GMC51
72GMC51
72GMC51's Avatar
No the belt doesn't rub there is plenty of room between the belt and hose its the bend thats the problem. I guess probably have a solid pipe made and use straight rad hoses to connect, unless someone else has any other ideas.
Old 02-24-2005, 11:13 PM   #6
smitty62
smitty62's Avatar
72--I can't help you with the hose, but I have a question? I'm considering a serpentine setup and I'm wondering if your setup came with that idler in place of the air pump? Or is that something you made yourself? Thanks!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-24-2005, 11:36 PM   #7
BobM
Had the same problem with my 71, but don't have the serpentine belt. If I remember correctly, think I used a hose made for the 72 Blazer which has the long pump. It has a sharp bend up at the water pump end. Fits perfectly on my truck. May be able to find the part number if you need it.
BobM is offline   Reply With Quote
Old 02-25-2005, 12:55 AM   #8
72GMC51
72GMC51
72GMC51's Avatar
It came with the idler pulley for the air pump. I bought the whole setup from Sallee Chevrolet at Salle-chevrolet.com, summit also sells it or you can buy it from many Local Chevrolet dealers. It comes with new GM water & power steering pumps, Alternator with plug, all pulleys, belt, all the brackets, bolts and instructions for $550.00 or $750.00 with a/c compressor.
Old 02-25-2005, 02:09 AM   #9
smbrouss70
smbrouss70's Avatar
I wish I could help with the hose issue, but if you do find a hose that fits please post the part # or application of the hose because I was considering this very same setup.
Also, I noticed that you have a sanden A/C compressor mounted in place of the radial unit thats supposed to go there, what did you do to make it fit?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-25-2005, 11:20 AM   #10
72GMC51
72GMC51
72GMC51's Avatar
The Adapter kit came from Old Air Products out of Texas, I used GM belt # 14097664, Goodyear # 6PK2520. I used their a/c system one thing though is the hoses do not come with both hose ends connected you have to measure them and either send them back to be made or bring them to your local a/c shop to have them crimped, which I guess is good if you want to run your line differant than factory. Vintage Air out of Florida crimp their hoses at a pre determined length in the complete kit they sell.
Old 02-25-2005, 01:14 PM   #11
smbrouss70
smbrouss70's Avatar
Thanks, I already have a Vintage Air system installed on my truck with a V-belt bracket. I wanted to put the serpentine system on there but I was thinking that I would have to use the radial compressor with the hose adapter kit to make it work.
I hope you figure out the hose thing, it looks like you're coming together there.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 02-27-2005, 11:26 PM   #12
72GMC51
72GMC51
72GMC51's Avatar
If you have the # of that hose it would be great, also a picture if possible.
JC
Old 03-02-2005, 12:24 AM   #13
72GMC51
72GMC51
72GMC51's Avatar
Finally have the solution I hope, had a piece of pipe bent and used parts of a stock replacement hose. Will have it made in Stainless tomorrow with a mandrel pipe bender, and hope for the best.
Old 03-03-2005, 09:56 PM   #14
67chevemall
Nice Job!
Old 03-03-2005, 10:34 PM   #15
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
nice valve covers
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
