Any of you guys running fuel injection?
I need a tank to go between the rails of a 68 frame. The motor I am using is a 98 LS1 and I need a fuel injected fuel pump and tank. Any ideas?
Get a fuel cell with electric pump, regulator, and filter!
0.02
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
I wanted an in-tank solution for my EFI also. When I purchased a new stock steel tank for my Blazer I had it shipped to Rock Valley in Illinois. They did a great job modifying the tank to accept an in-tank Walbro fuel pump. That was a cheaper route for me than the SS tanks you can get at EC, Brothers, etc...
you should pm fcg, ive heard nothing but good things about his tanks.
Mike
Check this link http://www.thedetailzone.com/Tanks%2...%20Install.htm There is a link in the article for the unit
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Mike
It is an in tank unit that is adjustable for depth and has a "baffle" to keep the pump fed.
yup, smokekiki... that's essentially the same unit I'm running w/ baffle... I had remembered seeing the Tanks Inc unit somewhere in one of my street rod magazines. When it finally came time to install... I couldn't find it so I decided to let Rock Valley install their version.
MY EX DRIVES A BROOM
the tanks out of 88-91 blazers will fit just need a few mods to your frame xmembers these are efi tanks and can use stock in tank pumps from tpi cars.
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#9 | |
What kind of frame xmember mods do you have to make, a local guy near me is parting out an 89 Blazer..............jt
2011 Camaro 1SS LS3/6 Speed |
look here http://www.geocities.com/cst68chevy/ , this is a board members truck (not mine) he used a pretty good idea i think.
I had a tank built by fuelcellguy. I am running TPI, awesome tank. Cuuldn't be happier.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Keep in mind a TPI or typical fuel injection pump will not supply enough pressure for a LS1. It will have to be a stock pump meant for a LS1 or a aftermarket unit.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Try Rock Valley Antique Auto Parts. They built my tank out of stainless steel with the TPI pump in the tank. I am running an LT-1 and getting ready to build a truck with a LS1 and plan to use them again.
http://rockvalleyantiqueautoparts.com/
1972 Blazer body...need to get a thread started for the rest of the story |
Rock Valley
Is the route I went also. It works great. But due to price, If I had to do it again, I would use fuel cell guy. I have heard only good things about him. My two cents, Kerry (LT1 in a 67 C10)
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
#15 | |
#16 |
Here is a link that someone posted that they put a new style camaro tank for the ls1 for his conversion.
http://67-72chevytrucks.com/vboard/s...ht=camaro+tank I used a blazer tank and aeromotive inline pump. Good luck
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
