Old 02-27-2005, 05:35 PM   #1
willow72
willow72's Avatar
eletric fuel pump?
im just finishing relocating my fuel tank and i am using a eletric fuel pump and i know they say you should put the pump as close too the fuel tank as possible but the closest place i can find with easy access is about 6 feet away does that sound too far away for you guys or what? have any of yall done this mod with eletric fuel pump if so where did yall mount your pump? thanks for any help yall can give me, john
willow72 is offline   Reply With Quote
Old 02-27-2005, 06:45 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Are you using the electric one as the main pump or an assistance pump? If its the main you should get it close to the tank, you want to prevent pump starvation or youll need a good tow truck number..........where did you mount your filler neck and what hose did you use?
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-27-2005, 07:04 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
We mounted my sons on the passenger side inner fender of his camaro and he has not had any problems at all. We also put an inline filter between the tank and pump to prevent any junk from the tank getting to the pump.
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-27-2005, 07:15 PM   #4
nitor
Too many projects
nitor's Avatar
I just put my original, behind the seat tank back in. With the new engine, I have to go with an electric because of the year of the block. I mounted the fuel pump to the floor under the cab. Just in front of the tank. I know this doesn't help, but that's where mine is. It's as close as I can get it.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 02-27-2005, 07:21 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In all reality, for an in cab tank, that is OK. Since it will siphon out, the pump is effectivly pushing the fuel instead of pulling it even though it is technicly down stream.
Willow...I would try to find something closer.
Old 02-27-2005, 07:33 PM   #6
willow72
willow72's Avatar
i did the behind the marker light thing wasnt as hard as i thought it was going to be had too get filler neck from cap reduced from 2 too 1 1/2 and tank filler neck 1 1/4 too1 1/2 at muffler shop also had too notch cross member on bed which is apain in the rear
