Unending Project
Gas Gauge Help?
My gauge reads over full all the time. I've checked the sending unit, and the wire to the unit, but I don't know what to do next. Any help?
Piper |
Professional Beer Tester
Piper,try unhooking the wire at the sender,turn the key on,and watch the gauge.If the gauge doesn't move,then touch the wire momentarily to a good ground.This won't be the same resistance as the sender,but it should tell you if the gauge is working at all or not.If the gauge doesn't move either way,you probably have either a bad gauge or the wire could be broken or shorted to the gauge.If it does move,then more than likely it's the sender.Hope that helps.Lynn
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
Unending Project
Thanks for that tip! Should've thought of it myself, but that worked, and I discovered that my sending unit was bad. Threw another one at it, and BAM! The tank reads correctly. Whoduve thunk?
Piper |
Who did you buy the sender from?
Fireman Bill |
Unending Project
![]() Piper |
