Old 02-26-2005, 11:25 AM   #26
stepside454
stepside454's Avatar
well, I can tell the valve covers arent stock. those are early 70s LT-1 Vette & Z-28 units, & the intake doesnt appear to be stock. so...its very likely the air cleaner isnt stock for the truck either
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 02-26-2005, 11:34 AM   #27
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
The top hat is stock for the air cleaner but the bottom dual snorkel part Im not so sure of. Im also thinking that 1984 is a little early for O2 sensors also.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-26-2005, 12:57 PM   #28
stepside454
They woulda had O2 sensor on cars in 84 (computer controlled carbs & distributer), but oddly, if you look close you can see the vacumm pot on the distributer.
Your right, the air cleaner lid is correct for the truck...but the base is from a camaro or Monte SS
Old 02-26-2005, 12:58 PM   #29
stepside454
it very possibly is a 305...likely hopped up a lil. thats why it has a lil ass to er
Old 02-26-2005, 01:02 PM   #30
84 PUMPKIN
You guys are sharp!
Stepside454
The Corvette valve covers, aluminum intake, and aluminum water pump are all GM parts that I purchased new at the local dealership. The breather setup is original and came on this truck from the factory. Well sorta. I added the driver's side fresh air intake to make it a dual snorkel. I used all GM parts except for the decal on the lid and the foam rings on the ducts. The decal is for a mid-eighties Camaro fender and the foam rings are shop-vac filters.
Mylilbowtie
The 02 sensor is a dummy. I used Camaro exhaust manifolds because they had a larger outlet and flange. Thanks for posting the pics for me.
My truck has 36 factory options and 2 dealer installed items but it does not have a H.O. 305 L69 engine. I don't think they came in trucks but I never say never. I've seen GM do some strange things.
84 PUMPKIN is offline   Reply With Quote
Old 02-26-2005, 01:49 PM   #31
stepside454
Pumpkin LOL sorry, for some reason I assumed these were the pics from the thread starter
Old 02-27-2005, 01:20 AM   #32
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
Originally Posted by CbHeEaVsYt
ok i know this it has OD which means th700r4 it appears to be stock motor but u never know i cant get to the casting numbers right away cause i have it in storage right now but got a chance to drive a day before i qeustioned the motor it says 5.0 305 on the radiator support stock sticker it is a silverado 82. i think it may have been a california truck cause jve never EVER seen that many vacuum lines and before i changed out the stock exaught for duals it had two catylac converters and 2 mufflers its got all the original smog pump and emmisions so unless some just ripped it out of a cali car whole then again u never know ive seen stupider stuff done well that is wat i can remember off the top of my head please tell me if i helped u ne my lil bowtie
ok yea and those pics werent from me LOL alright well my little bowtie tell me wat u think and i got the vin if u think that that will help u any further
cb
heres sum pics of my truck
82 silverado c10
heres my baby
1990 k1500
check out this 1957 chevrolet for sale
CbHeEaVsYt is offline   Reply With Quote
Old 02-27-2005, 06:43 AM   #33
MylilBowTie
Right turn Clyde
Vin can help to tell what is was factory installed. Until I can get some numbers of the block or some pictures its pretty much guessing. So far its a 305 - 700r4 from whats been stated but need to dig a little deeper to get the facts.
84 Pumpkin, I knew there was too much of a chance with not that being factory. It is a nice clean job tho. But after looking at it things just started screaming at me, that didnt look correct for it.
Old 02-27-2005, 04:48 PM   #34
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
i can try and get some tomorrow for y'all so when i get them ill posty them on here for u
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-28-2005, 12:21 AM   #35
crackajacka
Stylin
crackajacka's Avatar
i originally had a 305 h.o. in my truck before i chipped a piston and it would stomp the engine ive got in right now n do better on gas , but i guess whoever rebuilt the engine also put in flat top pistons in it also so that gave it more umph i guess.
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
