Old 03-01-2005, 12:40 AM   #1
ToonMan
ToonMan's Avatar
Dash Brake Light On
My 78's Dashboard Brake light came on about 2 weeks ago. I didn't even know it worked!!!!!! Any Idea why it has come on now and won't go off???
I looked for a switch on the E Brake handle and components under the dash, and saw nothing. And my brakes don't have sensor wiring run to them, so I am at a loss.
Any Ideas would be appreciated.
THANKS!!!!!!!!!!
Rob
Rob the ToonMan
56 Chevy Cameo----Custom, [Turquoise]
67 Chevy C10 Short Fleetside (Black & White)
63 Trailorboat-------Teardrop Style Trailer
69 Honda CM90
ToonMan is offline   Reply With Quote
Old 03-01-2005, 09:01 AM   #2
Phuloi68
You sure there is not a wire to your proportioning valve? When brake light goes on, it normally lets you know there is some kind of issue with either front or rear brakes. Ckeck brake line for rust-leaks. Especially line going back to rear brakes along frame where they usually rust out.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 03-01-2005, 09:16 AM   #3
beaterC10
The switch for the e-brake is not real visible. You might try pushing the e-brake lever all the way up by hand and see if that solves the problem. I have had the same issue and most times it was the e-brake.
beaterC10 is offline   Reply With Quote
Old 03-01-2005, 10:36 AM   #4
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Well, have you checked the fluid level? You didn't mention it in your post so I thought I would ask. Thats what it was on my vehicle.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 03-01-2005, 10:43 AM   #5
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
The springs in the break could be locked up. I know that does happen if its not use for a long time then it gets all lock up.
I am not a machanic so i dont know just what i know can happen.
Also the level of the fluid can do that to i knwo that. If it gets like bright to dim. i think. but maybe check the level
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 03-01-2005, 12:50 PM   #6
RockHQ
ROCKET POWER!
RockHQ's Avatar
Hands down the most common reason for the lit brake warning marker in this era of GM vehicles is leaking rear wheel cylinder(s). The second is a leak in the rear brake lines. And the third is seized up automatic adjusters which leave the brake shoes too far from the drums.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
