My buisy weekend
Well I got the lift on my burb this weekend. I put a 6 inch on it along with the 3/4 ton axles that I rebuilt with disc brakes all around. The only thing I need to do is get a steering stablizer and get the sway bar hooked up. The tires are 33 inches for now, they were just the only 8 lug wheels I had and I am planning on going with at least 36-38 inch this spring.
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
some more
![]() Join Date: Apr 2004
Are all those blockes under your leafs safe? I'm not picking on you, just asking. It seams like it could fold right over with any force. It looks good though.
I wish I had some jack stands like the ones in your first post.
looks great man. i'll be doing a similar swap in the next couple weeks.
couple questions, first where did you get those jackstands? those things are sweet. and also, on the rear breaklines did you find a bracket to secure the other end of the rubber line to the axle and then weld it on the axle tube? i'm looking for a little bracket like i have seen others use but i dont' know what to get it off of
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#6 | |
Thanks everyone.
#7 | |
Iv'e been running mine with 4" blocks in the rear and no trouble at all.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Randy if you will notice he has 2...2" blocks.. other than that... looks sweet..
Right turn Clyde
So would a shackle kit raise the rear? Wouldnt it be better than blocks? Ive never really messed with any of these things yet.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
yes a shackle flip can raise the rear about 4", ORD offers 2.5" and 4" lift brackets.. and yes it is much better than blocks..you can use your stock springs (unless you want more than 4" lift) so you can keep a softer ride and some flex...
#12 | |
#13 | |
![]() The shackle flip is more expensive but a better alternative then the blocks. You won't get the axle wrap as you would with the blocks. Project looks good. ![]() |
#14 | |
