03-04-2005, 01:54 PM | #1 |
87 Wanna Be K30
backfire... KA-POW!!!
what causes backfire on a carburated motor. the choke is unhooked and when the motor warms up it will backfire and lack just about all its power going down the road. mixture too lean? too rich? i cant even pull the truck out of the driveway. maybe the plugs arent fireing? double checked all the wires and they are all going to the correct cylinders.wires and plugs are all new. so is the cap and rotor. yea i think im lost
03-04-2005, 02:00 PM | #2 |
sounds like your timing maybe off...
03-04-2005, 02:21 PM | #3 |
In Progress
i had the same sorta thing, when it got up to a certain rpm it would backfire and gutless as hell. but it ended up being the collector gasket blew out
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
03-04-2005, 04:46 PM | #4 |
ROCKET POWER!
It's running lean. You have a vac. leak somewhere, or the carb is not functioning properly.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
03-04-2005, 05:47 PM | #5 |
Backfire out of the carb is to lean
Out of the tail-pipe is to rich. But be sure your timing is correct too. |
03-04-2005, 06:01 PM | #6 |
STOP! Hamma time!!!
Sounds like the timing to me. Did you put a Timing Gun on it yet?
Plan your work and work your plan!!!, or pitty da fool!! 87 GMC BaseTrim, 305 under the wrench/TH400/ 92 Chevy 1500, 350,TH700R4 sittin on dubs |
03-04-2005, 06:09 PM | #7 |
Chevys Kick A$$
Yeah, I was having the same problem and it was my timing. Either that or a vacuam leak.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
03-05-2005, 12:00 AM | #8 |
did you check the carb gasket?
-Levi |
03-05-2005, 01:44 AM | #9 |
I actually had my Q-Jet backfiring on me when it was waayyyy too rich just before I took it off. It was so rich that it was fouling plugs to the point where they wouldn't even fire within a week!! And it also lacked power like you say. But Yeah, It is most often like everyone else said-Lean or maybe a Vacuum leak. I have also heard of ignition modules doing that, but I'm not sure what setup you have.
