Old 03-04-2005, 03:21 AM   #1
gabet40
benefits/advantages of an H pipe?
Ive got sanderson headers to 2 1/2" dual pipes and magnaflows to 5" tips in the back. im considering puttin in the H pipe but im wondering what exactly the advantages are to them. anything?
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 03-04-2005, 04:27 AM   #2
barn9
Half a bubble off!
barn9's Avatar
Better sound, equalization of engine pressure, and better sound. Personally, I would not have duals on anything without it.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 03-04-2005, 08:18 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It helps to boost the low end torque a little. In all reality, many times it is not noticeable, but it quiets down the exaust a bit and does make it sound better as barn mentioned.
Old 03-04-2005, 08:53 AM   #4
chevyfarmer
chevyfarmer's Avatar
I put an H pipe on my 67 after I had put the duals on and did notice a sound difference. As far as the torque or performance gains they were minimal. What are everyone’s ideas on exactly where the H pipe should be installed for maximum gains? After I had installed mine (of course) I was told that the best location for one was determined by drawing lines down your exhaust pipes with a wax based china marker. Then drive it around for a day or two and checking where the wax stopped melting off, and that was suppose to be the best location. ?????
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 03-04-2005, 09:12 AM   #5
Longhorn Man
I have always been told to use spray paint and run it around the block and then look for the same as you describe.
This mod can make tranny removal a real PITA, it wouldn't be a bad idea to install an extra set of header collectors just south of the tranny so you can unbolt the whole H-pipe as an assembly for tranny removal and not ruin your pipes.
Old 03-07-2005, 12:25 AM   #6
gabet40
ya i forgot that you have to place it there and it turns out the way that my exhaust is that the only way to do an H pipe around the tranny is to have it come down and across from each side. I put the same pipes from my lowered 69 1/2 ton on the blazer so theyre tucked up pretty nice.
would u guys still recommend the pipe with the additional complications involved?
Former owner of:
Old 03-07-2005, 12:37 AM   #7
4x4Poet
Related hijack: Any thoughts on the advantages of an X-pipe over an H-pipe? Or vice versa?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
