04-12-2002, 07:12 AM | #1 |
Slop in steering
My brother-inlaw just bought a 71 lwb. He said is drives pretty good except for excessive play in the steering wheel. Can this be adjusted at the manual steering box and how much play can we take out?
04-12-2002, 07:51 AM | #2 |
you should be able to turn the wheel to one stop and then adjust it, turn it to the other stop and adjust it and see what happens in the middle. you can also turn the big nut on the bottom to adjust too. Don't quote me on these cause I can't remember for sure anymore. It may be like mine was and have the gears inside rust pitted so bad that it won't ever get better. I have a seal and bushing kit for a manual that I will never need if you are looking to get one. I dunno $20 or something? let me know. good luck.
------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran Nathan & Tiffany |
04-12-2002, 08:13 AM | #3 |
Check your suspension components. I have the "Final Four" in my steering wheel and I replaced both tie-rod ends and now I can keep it on the road.
------------------ 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne ----------------------- Slaughter, La |
04-12-2002, 10:29 AM | #4 |
He says the truck doesn't wonder or feel loose. It just has too much play.
04-12-2002, 12:06 PM | #5 |
Weapons Of Construction
Check your drag link where it attaches to the steering arm. Not sure on these trucks, but I had a Monte Carlo where the drag link needed replaced. Unfortunately, the part that was wore out was permanently attached to the drag link. It would wander enough to almost scare the crap out of you.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
04-12-2002, 03:48 PM | #6 |
I am a Referee of life.
There is a 5/8 nut with a allen head bolt thru it on top of the box.You may be able to tighten it a bit there but don't go beyond even with the top of the nut.If that doesn't take enough play out replace the box.BTW go a 1/2 turn or so at a time and turn lock to lock between adjustments.
------------------ Deland does Chevys 68Chevy panel(LIZ) "A man and his truck,it's a beautiful thing" "I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-12-2002, 04:59 PM | #7 |
How's the rag joint?
04-12-2002, 05:08 PM | #8 |
The pitman arm bushing tends to wear out in those boxes also so check that too. like I said I have a rebuild kit bushings and all, for that if you want.
------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A [This message has been edited by texnician01 (edited April 12, 2002).]
04-12-2002, 08:49 PM | #9 |
You can take out play with that adjuster on top of the steering box. BUT do not over adjust it!! You can ruin the box. Take out enough play to make a nice diffrence. Don't try to make it perfect, you could mess it all up.
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Woodstock,IL.northwest of Chicago It's not what you buy, it's what you build!! I did not climb to the top of the food chain, to become a vegetarian. For some pics of my truck. |
