Old 07-22-2002, 11:54 AM   #1
WB72
Before and After
WB72's Avatar
Is there a way to determine where the crossover should be? would it depend on the size of pipe? I heard that you should run new exhaust for about 1/2 Hour, the pipe will darken and that is where the optimum place for the H pipe. If this is true, it would take 2 trips to the muffer shop, who has time for that?
Where does you H pipe fit in your system, how far back from the end of the collector?
Just want to be able to do mine once.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
