Old 03-10-2005, 01:37 PM   #1
jetfixr
late model steering wheel
My stock wheel was pretty thrashed so I ordered one from a 94 silverado off of ebay. There is a spacer/horn contact peice that seems to make the wheel stick out a bit farther then it should, also can't figure out how to mate the new horn cap wiring with this spacer/horn contact peice. I know this has been posted somewhere before, but with the search function down it is burried somewhere in 1241 pages =(
jetfixr is offline   Reply With Quote
Old 03-10-2005, 01:40 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Hopefully Longhorn Man sees this. He uses that wheel alot and probably has some insight.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-10-2005, 02:47 PM   #3
72 Cheyenne402
72 Cheyenne402's Avatar
I Have The Same Problem
72 Cheyenne402 is offline   Reply With Quote
Old 03-10-2005, 03:23 PM   #4
john
member #16
john's Avatar
There is some horn info here
john is offline   Reply With Quote
Old 03-10-2005, 03:28 PM   #5
flip66
flip66's Avatar
you can get the horn peice from the Help section at the parts store.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 03-10-2005, 10:11 PM   #6
jetfixr
Thanks John that was the post I was looking for. The wheel still sticks out a bit but it looks like there about a quarter inch of material on the back of the 94 wheel that can be removed and it will sit a bit more flush.
