03-10-2005, 10:57 AM | #1 |
Power brakes
I want to convert my 66 3/4 ton to a disc/drum set up and have everything to do it except for the brake booster and new master cylinder. Is there any reason why I can't or shouldn't use the booster and master cylinder set up from a 67-72 truck? Or, does anyone have any suggestions on which set up I should use?
Thanks |
03-10-2005, 03:08 PM | #2 |
Designated A-hole!
If you can bolt it on I don't see why you couldn't use it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-11-2005, 10:44 AM | #3 |
Thats what I was thinking, just didn't know if modifications to the armature would have to be made or not. I've definitely got enough room on my fire wall to bolt it up.
03-11-2005, 11:32 AM | #4 |
Msgt USAF Ret
disc brakes
I think you will need the master cylinder and the prop valve from the disc setup as the disc calipers require more fluid volume and pressure. Here is a FAQ thread on it.
http://67-72chevytrucks.com/vboard/s...d.php3?t=35042 VetteVet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 03-11-2005 at 11:42 AM. |
