![]() Join Date: Jan 2005
Problem with quick restarts
I have had a problem with my 69 SWB Fleetside. If I turn it off and then try to start it right back (like if I stop for gas and finish too fast) it won't start. But if I sit for a couple more minutes it starts right up. My mechanic changed out the positive battery cable thinking it was too small and heating up. But that didn't help. I don't have any problems as long as I remember not to try and start it right away. So for quick stops, I have to leave it running. Any ideas?
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
68cst_ss490
sounds like the heat is killin the starter. try a heat shield or heat wrap on the starter or mount a remote starter solenoid on your fender
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
#3 | |
its all about the +6 inches
Crank w/no fire? No crank? Crank slow farts through the carb? shoots fire out the carb...or the tail pipes...or BOTH ![]() Need more details. Also, your engine combo will help too. |
No crank, like dead battery. But wait a couple minutes and fires right up.
Saving 1 truck at a time!
Any click from the starter solenoid when you try? I know you said "like a dead battery" but we still need more. Mine would do this after I cranked on it a bit. Let sit and it would start. Crank too long...nothing...no click or anything. I replaced all the grounds and it got better but never healed completely. Some connection was heating up and going dead. I finally ran an additional hot lead from the starter solenoid to the battery. When it happenened again I would put the lead on the battery and it would start right up. I know it is not the starter or solenoid...it is wiring somewhere. Try this bypass to make sure it is not the dreaded heat soak problem.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
More trusty Less rusty
can you turn your lights,ect. on when it won't crank?if you can sounds like bad starter.
Heat soaked solenoid...get a heat shield.
I am currently in Santa Barbara, but will try those things this weekend. Thanks.
Registered Cruiser
Check the powerblock on the passenger side inner fender. Make sure everything is clean and tight. New connectors, and a bright shiny powerblock can do wonders for these trucks.
I intend to live forever. So far, so good. |
I had a 350 in a 70 that would not start hot. The solenoid would click but no crank let it sit a few minutes and it would start fine. The bushing in the starter was bad and the heat would cause it to lock up. When it cooled off it would spin free. I installed a new bushing (cheap if you can find them) and it worked great.
#11 | |
CCRider
I second that
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Are those standard equipment, something I can find at the yard, or do I need to make one?
#13 | |
This will take care of it:
http://www.madelectrical.com/catalog/st-1.shtml
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#15 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I have oftened wondered with this remote solenoid how the starter bendix gets engaged to the flywheel. Anybody know?
VetteVet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#16 | |
#17 |
![]() Join Date: Jun 2002
I had the same problem as LT4EXTREME, if the bushing is worn and the starter heats up the armature will hit the outer housing and lockup. I found this out after I had put in a heat shield, remote solenoid, and everything else I could think of...
Sometimes the simplest things kick your butt... Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#18 | |
Msgt USAF Ret
remote solenoid
![]() VetteVet
#19 |
This space for lease
![]() Join Date: Mar 2005
My 69 was leaving me stranded at times as well. I to added the heat shield between my headers and the starter and protected the connections at the solenoid but continued to have the same problems. I finally drove the truck till it was good and warm then stopped at the parts store for a run on the diagnostics unit. The system said my battery was dead. Once the truck cooled slightly, we started it and did the test again. It said the system wasn't charging at that point and to test the regulator. It failed! My problem wasn't at the starter but rather the regulator under the battery tray. Ultimately, my alternator gave up the fight a short time later as it was being overworked by the faulty regulator. Just another idea.
If everything seems to be going well, you have obviously overlooked something. 1972 K-20 l/f 383/350 a/c "custom camper" 1987 V-20 l/f Silverado - project |
#20 | |
