Old 03-10-2005, 11:38 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Plans for the weekend?
So since tomorrow(friday) my weekend starts when 1 0'clock comes around I thought I'd ask what you guys have plan for this weekend.
So i got friday 1pm till i kick myself out of the garage, saturday & sunday morning till about 7pm
My To-do List
-finish passenger floor
-start driver side floor
-fab up some parts that arn't reproduced
-install my fuel line, pump, and filter
-finish brake line installation
-finish the body mount installation
-install radiator support
-bolt in transmission crossmember
-pull out rear inner wheel fender and fix what little rust they have
and, maybe if I feel peppy, redo a section of the windshield.
goodluck to me.
Alexis is offline   Reply With Quote
Old 03-10-2005, 11:40 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Well I just order the sheet metal today from wes so I am guessing next weekend will be trcuk day... Well maybe I can break out the welder fro alittle while..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-10-2005, 11:52 PM   #3
c-1072
weekend
well if all goes well i might be goin to get a parts blazer tub for myself . I know it might dissapoint some but i would like to drive my blazer this summer and getting a tub with solid floors would save me a month and a half . Plus i might consider saving the parts from the old tub and offing her up to board members sacraficial style . Ok last beer i will let you know sunday night .
c-1072 is offline   Reply With Quote
Old 03-11-2005, 12:31 AM   #4
Alexis
Member since 2000
Alexis's Avatar
lucky!
I wish I could of saved all this time and got a nice tub........can't wait forever though.
Old 03-11-2005, 01:14 AM   #5
JBstor
JBstor's Avatar
Well, I have been working on mine every day, and a lot of nights (self employed). Today I tried to fire up the old beast. ---------HEI has no spark. I have a spare in another non runner though, so I gave up for the day, gonna start fresh tomorrow and go outside with a screwdriver and a 9/16
Tomorrow is maybe the day! The nice lady in my house says she would like to see me once in a while, so I might take tomorrow off........well, after 6 pm or so anyway, mebbe 7. But Saturday I start again. Saturday is a workday, Right?
JB
JBstor is offline   Reply With Quote
Old 03-11-2005, 01:26 PM   #6
71jimmy
71jimmy's Avatar
Alexis, your weekend list would take me about 6mos, good luck. I'm currently stripping the bed floor and sides. Got one side done, hope to do the other this weekend. Takes forever.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-11-2005, 01:50 PM   #7
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
My K5 will roll out of the garage this weekend. I am very committed to that. Fri night, All day Saturday should just about do it... This is good, I can collect my thoughts 'out loud' here.
I did change the distributor and rebuild the carb at the same time, so I am expecting fun times getting it all dialed back in.
LH Axle new u-joint press in
Press lug studs and lock new rotor onto old hub
Clean old hub and inspect races
pray that I don't need to change races
Pack and install new inner/outer hub bearings, seals
Replace 2 broken spindle studs
Clean spindle and pack spindle bearing
Install spindle and backing plate
Install hub assy and locking hub
Install new caliper and SS brake line
Remove old brake line and caliper
torque rear u-bolts to spec
Install dual stabilizer up front
remove old dual exhaust system
Get the old girl started
Get out of garage
a) air down 38's enough to lower few inches
or b) use neighbors suburban wheels/tires
Bolt and/or air 38s back up
Set timing and idle
Recheck everything
Maiden voyage
Wash it
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 03-12-2005, 12:14 AM   #8
desertchevy
I got my weekend started early. Told the wife that I was going to keep it and to deal with it. Pulled the front clip off today (motor and trans tomorrow) and removed a 10x14 section from the left rear floor that had some rust. Started gasket match porting the bb heads last night. Called and got a small 401K loan today and when it shows up going to take a trip ECC and get all of the patch panels and a complete 68 frontend with a cowl hood..Here are some pics of it as it sits now
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
