Old 03-10-2005, 04:55 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Driver side firewall picture needed
Well, I'm puttin' the truck back together and I've slept several hundred times since I took it apart. To make things worse the pictures I took when I disassmebled it have vanished. I was wondering some of you could post pictures of the firewall (engine compartment side) showing the holes, brackets and wiring coming thru the firewall. Also, a few shots of the underside of the dash on the driver's side would be real helpful too. Thanks
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-10-2005, 05:10 PM   #2
pat
pat's Avatar
Dont know if this will help much.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 03-10-2005, 05:11 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Yes, that does help! Thanks
[IMG][/IMG]
[IMG][/IMG]
Just Passin' Thru
Old 03-10-2005, 05:12 PM   #4
flip66
flip66's Avatar
I do not know how far you are from Garland "north of Dallas” but I have a 72 with no front end or motor and nothing in the dash with everything still running through the firewall if you want to come by and look at it. I will try to get you Photos Tonight.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 03-10-2005, 06:48 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
Garland's a tad far, I live just south of Austin. Pictures will be greatly appreciated. Thanks,
Just Passin' Thru
Old 03-10-2005, 07:04 PM   #6
shifty
Questionable
shifty's Avatar
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-11-2005, 12:30 AM   #7
flip66
flip66's Avatar
pic
out side firewall
Old 03-11-2005, 12:31 AM   #8
flip66
flip66's Avatar
pict
outside center
Old 03-11-2005, 12:32 AM   #9
flip66
flip66's Avatar
pict
inside by fuse panel
Old 03-11-2005, 12:33 AM   #10
flip66
flip66's Avatar
pict
inside center
Old 03-11-2005, 12:43 AM   #11
72 CustomCamper
huh ???
72 CustomCamper's Avatar
This might help too...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-11-2005, 12:06 PM   #12
shifty
Questionable
shifty's Avatar
I have the truck at work today. I can go out and snap some close-up shots if you want. Just lemme know.
Old 03-12-2005, 03:05 AM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks guys!! The pictures told me waht I needed to know..
Just Passin' Thru
