Old 03-07-2005, 12:21 AM   #1
c10chevy69
c10chevy69's Avatar
Friggin' U bolts
With so many of you having lowered your trucks, How the hell did you guys get the U bolts off? After 33 plus years those nuts are really on there! Any suggestions? I don't have a compressor if that helps any.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 03-07-2005, 12:26 AM   #2
67cst
i love summertime
67cst's Avatar
get a grinder and cut them off maybe? or torch..even a sharp blade on a hacksaw would be faster then trying to get the nuts off
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 03-07-2005, 12:28 AM   #3
clay68c10
clay68c10's Avatar
Lots of penetrating oil over a few days and the "death bar" (three foot long cheater bar on a breaker bar). Be ready to fall if the bolt breaks.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-07-2005, 12:29 AM   #4
longhorn71
longhorn71's Avatar
cut them.i used a grinder with a cut off wheel.A cutting torch makes fast work of them too.The welding shop here in town charged me 11 bucks a peaice for them.U-bolt in my opinoin should not be used more then once.they strecth after they have been used.The ones on my 1-ton were the originals and were rusted part wat through too.rember they are the only thing holding the rear end in your truck,so for safety resons replace them
longhorn71 is offline   Reply With Quote
Old 03-07-2005, 12:31 AM   #5
4x4Poet
What did you do to prepare them to come off? At the very least, wire wheel the threads and then apply penetrating oil. Maybe use the hack saw to "straighten" out some of the nicked threads. Unless you have that large of a thread cutting die, of course. Also, the longer the rachet or breaker bar, the better. Or extend yours with a pipe. I'm out!
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-07-2005, 12:35 AM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
The only way is the firegod,those dudes won't come loose in most cases,and if you're gonna lower it,you'll need new ones anyway.
Grinder with a cutoff wheel works too,but a torch get it done quick.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-07-2005, 01:27 AM   #7
powell72
powell72's Avatar
Get'em hot with a torch and use a big pipe!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-07-2005, 01:37 AM   #8
screamin_c102
screamin_c102's Avatar
Talking
Wrap a chain around the axle and the connect the other end to a fire hydrant, then floor it. Be prepared for a sudden stop if the bolt doesn't break.
screamin_c102 is offline   Reply With Quote
Old 03-07-2005, 02:43 AM   #9
krue
Designated A-hole!
krue's Avatar
Oxygen + Acetylene makes that an easy job. Besides everybody needs a torch and you will find a hundred uses for it after you get it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-07-2005, 05:02 AM   #10
SLS
Finish the'71..or bust!
SLS's Avatar
You may want to give heating them up with a good ol' Propane torch a try.
I have been able to get rusted bumper bolts, coil spring holder bolts, and U-Bolts off just by getting them hot with Propane...and then using a 3/4 inch drive with a cheater bar.
I learned the hard way (cursing and bleeding knuckles)....until I was told to try this method. It has worked good for me so far, but the bolt heads were not buggered up.
On the bolts that are 'rounded off', I whip out the air compressor and the cut-off wheel and watch the sparks fly.
SLS is offline   Reply With Quote
Old 03-07-2005, 07:20 AM   #11
LONGHAIR
For those with-out the benefit of a torch or air compressor.....there is a trick.
As everone knows, once you get one side cut loose with a recipricating type of saw (Sawsall) you have problems with cutting the other side because of the vibration. The "trick" is to cut one side about 3/4 of the way through and while it is still holding tight cut the other side. Then when it is cut through you "break" the other side with a long ratchet/socket by turning it. (either way it doesn't matter) Be prepared for the "Pop!" 'cause there will be one. The older and rustyer the spring stack.........the bigger the snap will be.
LONGHAIR is offline   Reply With Quote
Old 03-07-2005, 09:02 AM   #12
400ex
Well, c10chevy69, I did it the old fashioned way. Let some penetrating oil work its way in for about a day. Got a 3/4" drive breaker bar and socket and then dang near strained my berries loosening the nuts off. My crappy impact wouldn't even phase them. And they all fought me then entire way off.
James
400ex is offline   Reply With Quote
Old 03-07-2005, 10:30 AM   #13
arkracing
Weekend Warrior
I personally like the "fire-wrech" method - but you can heat them up with a propane torch and see if you can break them loose with a cheater bar - you might have to re-heat them if they start to get hard to turn again
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-07-2005, 11:23 AM   #14
raggedjim
raggedjim's Avatar
I used a cutoff wheel in the very center of the top (1 cut per bolt vs. 2 cuts) Longhair is right, they will make a hell of a pop when they split! Once the bolt is cut thru use a cheater bar and socket to rotate it and then it will drop out.
Most of these I have ever seen aren't worth saving after 30 years of rust, so cutting isn't a big deal.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 03-12-2005, 01:42 AM   #15
c10chevy69
c10chevy69's Avatar
Where can you get new u bolts without having to order them? I know that they come with the kit when you lower a truck but mine is not going to be lowered. I just need new ones to replace the soon to be mangled ones.
Old 03-12-2005, 01:50 AM   #16
JBstor
JBstor's Avatar
Any good spring/alignment shop should be able to make you up some new ones no problem.
JB
JBstor is offline   Reply With Quote
Old 03-12-2005, 11:05 AM   #17
68haywagon
I'm watching you!
Well I just wen through this replacing my trailing arms. I salvaged one U-bolt by busting my ass, the other I had to cut. No one in town had any new ones in stock and I ended up going to a spring shop and they bent up 2 new ones in about 3 minutes for $30, they told me that they needed an old one as an example luckily I saved one.
Good Luck!
Mike
68haywagon is offline   Reply With Quote
Old 03-12-2005, 11:49 AM   #18
mac
Active Member
mac's Avatar
And take a REAL good look at the diff tube. I had rust thru that required a patch be welded on. The U-bolts and cab corners ain't the only places that mother nature uses to bring 'em back to her.
___________________________________________
Mac '67 ZZ4/700R4 Dropped and Shaved with an Eyebrow trim
mac is offline   Reply With Quote
Old 03-12-2005, 07:50 PM   #19
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I cut mine with a torch and then a disk grinder to clean up the slag enoughf to get em through the holes..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-13-2005, 12:54 AM   #20
longhorn71
longhorn71's Avatar
The weld shop in town bent up 4 for my 1-ton.It was 45 ucks for them and they need to see peices of the old one to make them
Old 03-13-2005, 01:14 AM   #21
TRUCKGUY
TRUCKGUY's Avatar
breaker bar works GREAT thats what i use on all of them with 2foot pipe in some cases.. spray penetratin oil on them to it really helps lol
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
