Fuel guage problems
My fuel guage does not move anymore. It has found its resting place past the full mark, it hangs out at about the 2 or 3 o'clock position and just sits there. I know I need a new fuel sending unit in my gas tank but why did my needle go completly out of the e to f range? thanks for any help, and where do you recomend I get an aftermarket fuel sending unit
Mike... |
Member since 2000
check your connection on the fuse box..........it should be a brown wire if memory serves me right, it is just a female connector that conects to the fuse box......it comes out sometimes. If it isn't that then well move onto the next thing, sending unit or the wiring to the gauge.
goodluck, i know other will give other ideas. |
While we are on the subject. My gauge works
but wiggles back and forth about a half inch even when it is sitting still. Do I need a new sending unit ? ![]()
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
I've got gremlins in my fuel gauge too (in my 3/4 ton). But mine jumps from normal to way past full (about 3 or 4 o'clock), stays there for a few seconds, then falls back to normal. It does this continuously.
72 GMC Jimmy 72 GMC 3/4 ton Camper Special 70 Chevy 3/4 ton (in pieces) FOR SALE! |
If your gauge goes way past full, then you probably have an open circuit between the sending unit and the gauge. Check that the brown wire from the tank is connected (both at the tank and at the fuse box). If the brown wire is OK (test at the fuse box with a multimeter 90 ohms is full, 0 ohms is empty) then the open could be in the printed circuit harness.
typical fault tree needle way past full..... open circuit between sending unit and dash sending unit is bad needle stays on empty... short between sending unit and dash leak in sending unit float needle works but only between 1/4 and empty 82 ohm ballast resistor behind gauge is bad needle bounces around bad gauge Use a multimeter when in doubt. |
Nice troubleshooting steps ssls6. Any idea if you can fix the bad guage that bounces? What part in the guage would cause it to bounce?
I just replaced my tank, sending unit etc and filled up for the first time and I got the bouncy gauge syndrome.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Thanks ssls6,
The trouble shooting guide is great! Looks like I'll be shoping for a new gauge.
The LuvShack Garage
HMMMM, BRAND NEW SENDING UNIT HERE, READS EMPTY, SOUNDS
LIKE THE FLOAT ON MINE MAY HAVE SANK / GOT A LEAK IN IT. ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice trouble shootin guide hope fully it will help me on mine bad guage...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Luv2xclr8: or maybe you got a short according to the trouble shooting guide above...
Mike |
#11 | |
The LuvShack Garage
WE CHECKED IT, MIGHT HAVE MISSED IT, BUT IT LOOKS AS IF IT'S THE FLOAT ![]()
