Where do you connect ground straps?
Ok guys I got the groundstrap kit and the previous owner wiped out al the other ones minus the bed one so help me out here
![]() Thanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Forgot to mention that this was on a 68 1/2 ton with a v8.
Cab mount to cab, valve covers to cab, I think thats all there is besides the wire on the rad support near the horns.
Gee_emm
Which cab mount gets it? I have 2 for thevalve covers and 3 for the cab to frame. At least that what the kit says and that all it says.
Now that I think about it I belive both cab mounts get one, I just looked through the entire assembly manual but I could only find a picture of the enigne straps.
its all about the +6 inches
If you are just doing this to get your lights and stuff working, then it really doesn't matter where you put them.
I have not seen a cab with (5) ground straps on it. The four that I am familiar with are: (2) for the valve covers to firewall, (1) for the right front cab support to the frame mount, and (1) from the right front fender liner to the frame.
Jim |
Ok I got the valve cover ones taken care of. I found the pass side cab support to the frame mount but I cant locate the right front fender liner to the frame one. Anyone got a pic?
This pic is from a very low mile unrestored 72.
There was a cab to frame ground strap on the right side only on that one.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
![]() Join Date: Mar 2003
I always remove the little valve cover ones, they look really stupid to me. I pick one of the holes in the back of the cyl. head and hook a wire form there to the firewall and call it good. I still have the battery cable to the front of the pass head, then there are the straps under the cab. Should be plenty unless you are running a computor.
The inner fender to frame ground strap is often down by the lower radiator hose. I think there is a hole near the kick-up portion of the frame rail.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Ok...Maybe a stupid question, but do I need to run a strap to the frame from the engine?
