03-13-2005, 08:51 PM | #1 |
December 21, 2012
73-87 3/4 ton disc brakes interchange with 67-72 3/4???
Thinking of converting my front drums to disc on the 3/4. Have heard that 73-87 3/4 disc system will work if you use the 73-87 ball joints and tie rod ends. Anyone know if this is true??
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
03-13-2005, 08:59 PM | #2 |
I have a 71 3/4 ton with front discs that i am wreckin.Would you be intested it these parts?
03-13-2005, 09:15 PM | #3 |
71-87 should be the same pcs on the 3/4 ton trucks.....the 1/2 ton trucks change after 72 on some of the pcs......69L
http://community.webshots.com/user/hotrodhorn |
03-13-2005, 09:17 PM | #4 | |
December 21, 2012
Sent answer to your PM.
03-13-2005, 09:19 PM | #5 |
The 73-87 parts will give you a small lift in the front if that's what you go with. Some like that and some don't.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
