07-21-2002, 07:06 PM | #1 |
creator of kong
Off topic, but can somebody run my motor on desktop dyno?
I seem to have either lost my disc or loaned it out and I haven't loaded dyno on my new puter yet............this engine is a 421 sbc...
block is 4.155 bore stroke is 3.875 comp. is 13.75 to 1 (or very very close to it) AFR 220 cc aluminum heads......2.10-1.65 valves 62 cc chambers 6 inch rods single plane Super Victor intake alcohol Braswell 970 cfm carb. open headers 1 3/4 tubes cam is a Lunati solid roller specs are : Dur. at .050 is 262 int. and 271 ex. Gross dur. is 301 and 309 Lift is .626 and .626 int. opens at 29 deg. btc and closes 53 abc ex. opens at 65 deg. bbc and closes 25 atc hope this is every thing....Thanks |
07-21-2002, 11:11 PM | #2 |
Looks like hp is 487 at 4500 and tq 635 at 3000. If I got the #s right.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-21-2002, 11:14 PM | #3 |
ah come on!!! My go-cart makes more than that!!! LOL!!! J/K
07-21-2002, 11:16 PM | #4 |
its all about the +6 inches
The mild motor for the daily driver?
07-21-2002, 11:22 PM | #5 |
Sorry, I'm in a mood tonight!!!
07-21-2002, 11:28 PM | #6 |
Desktop dyno is just a program to give you rough #'s. If you really want to know PUT IT ON THE DYNO. You can't get very exact with it. I'm sure it makes more but thats what the PROGRAM says like it or not.. Aint no need to crack on it. Looks like a stout motor to me. I'm sure it cost more than your go cart! So to speek. Nice mood huh!! Dont take offense just trying to loosen things up.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 07-21-2002 at 11:32 PM. |
07-22-2002, 08:08 AM | #7 |
I wasn't "cracking" his engine!!!!!! I was just having some fun. I would only be happy to have a engine that made half that power! Sorry, but I did take offense. I was just kidding around. That's what "J/K" means, Just Kidding. And by the way...I don't have a go cart.
07-22-2002, 09:12 AM | #8 |
I thought my 415 was a wild motor. Where do you plan on putting this motor? The Hp numbers look low. Also, is that a stock damper on the front of the crank? I don't think those are suposed to see much action over 4500. Thats just getting this motor started isn't it?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
07-22-2002, 10:56 PM | #9 |
Guys, you will be glad to know it was put on a dyno today.(it's good to have friends in the business)...........old engine pushes out just a taste over 600 hp.......Thanks for the help on this.....
we did some changing on the cam degrees........6 retarded, as a matter of fact and it went to 618 HP at 6,000RPM and 597 ft. lbs. of torque at about 5,000 rpm......................this is the way I like it!!!!!!!!!!!!!!!!! whooooooooooohoooooooooo......Thanks for the input guys..............Brad aka "flyin99".or used to be...............
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood Still in progress ........... |
