Old 02-22-2005, 12:00 AM   #1
Stevonator
such a thing?
Did any of the 73-87 truck come with 6 lugs? just curious.
Stevonator is offline   Reply With Quote
Old 02-22-2005, 12:13 AM   #2
Russell
Professional Grade
Russell's Avatar
Heavy half trucks, and all non 8 lugged 4x4s were 6 lugged as far as I am aware
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-22-2005, 12:21 AM   #3
smokinn
smokinn's Avatar
my 82 4x4 is 6 lug.
smokinn is offline   Reply With Quote
Old 02-22-2005, 01:07 AM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Heavy half (and big 10) 2wd trucks were 5 lug.
All 73-87 1/2 ton 4x4 trucks were 6 lug.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 02-22-2005, 09:20 AM   #5
Mike76251
My 84 "Camper special" aka "Heavy Half" has 5 lug.
Mike76251 is offline   Reply With Quote
Old 02-22-2005, 10:17 AM   #6
ElGracho
ElGracho's Avatar
A camper special and heavy half are different things. They each required/included a unique combination of options. The heavy half package was basically a way for GM to offer a half ton truck that could still burn regular gas in the late 70's. The camper special is just like it sounds, made for those who wanted to use their truck to haul a slide in camper. The trailering special is something else too, for pulling a trailer...
Joe
Old 02-22-2005, 12:45 PM   #7
Mike76251
Yeah..........they are different animals alright.
I don't know what to call mine but it has the big brakes and the 3/4 ton rear springs.
I thought GM quick calling them "names" and just let you order one with the options as you saw fit by '84.
Old 02-22-2005, 03:48 PM   #8
Paso76GMCstepper
Paso76GMCstepper's Avatar
My 76 GMC K15 has the big brakes and 6 lug.
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 02-22-2005, 05:03 PM   #9
Stevonator
The spindles are all the same correct?
Old 02-22-2005, 07:50 PM   #10
MJN
MJN's Avatar
The spindles are completely different because the 5 lug is two wheel drive and the 6 lug is a 4x4. The spindle for a 5 lug isn't part of an axle like the 6 lug is. You can't use a 6 lug spindle on a 5 lug truck, just won't work.A picture would work the best, any one got one to help me out here?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-23-2005, 12:25 AM   #11
Stevonator
I'm putting the whole front off of a 73-87 2wd under my 69 2wd. Trying to make up my mind whether I should go 5 lug all around (redrill the rear axles) or whether I could come up with 6 lug rotors without a redrill.
Old 02-23-2005, 12:31 AM   #12
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
my 81 rear wheeler was a 6 lug.
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 03-14-2005, 03:36 AM   #13
Dooley
Dooley's Avatar
In the middle 70's GM did offer a 1/2 ton 2wd with optional 6 lug. I've seen a few 2wd 1/2 ton with the option and 16" wheels. Also I had a 77 Suburban 4wd 6 lug at the same time as a 76 SB pickup 4wd that was a 5 lug. Go figure!
Dooley is offline   Reply With Quote
