Old 03-13-2005, 01:09 AM   #1
Nima
Blue 67
This weekend project
Well, this is what I started yesterday. The floor is not really rusty. Those copper colored things are mainly the old carpet which on some areas were glued to floor by po. I just has some surface rust.
Nima is offline   Reply With Quote
Old 03-13-2005, 05:05 AM   #2
4x4Poet
POR15? Get deep down in the seam where the firewall meets the floor. PorPatch seam sealer will go over treated rust. Look closely where the kick panels meet the floor. GM applied seam sealer between the two, but not enough. Fill any gaps after trying to clean out what's between them short of the original sealant.
Sorry; I'm doing front floor, rocker, & kick panel patch panel work on my K10 right now. Couldn't resist giving advice.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-13-2005, 11:43 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What is that on the floor??? Por 15 all the way just do not get it on your hands.. I just bought some more por for my blazer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-13-2005, 12:08 PM   #4
Nima
Blue 67
That is rust encapsulator from eastwood. I applied it after sanding the area and washing it with zinc sulfate solutation.
4X4poet, don't be sorry, I always appreciate advice. You mean I should remove all the old seam sealers and put new ones? In most of the area I didn't see any evidence of rust. Thanks again.
Old 03-13-2005, 12:55 PM   #5
chevyboy55
chevyboy55's Avatar
Gotta love that steering wheel cover!
chevyboy55 is offline   Reply With Quote
Old 03-13-2005, 09:25 PM   #6
Nima
Blue 67
Well, after couple of coats of primer and first coat of ultra silver paint. I have one question though.When I paint (I am using spray cans), at then end of each hand stroke I get more paint at the edge. How can I prevent that? Now, I am trying to stop spraying before I get to the end of the line and also I try to move my hand faster. Any tip in this regard would be greatly appreciated. Thanks
Old 03-13-2005, 09:31 PM   #7
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Try spraying in one direction, not back and forth.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 03-13-2005, 10:45 PM   #8
4x4Poet
Wire wheel down deep in the firewall to floor joint so you get out the dirt that slipped between the sealant's cracks. Also, as much rust as possible. Then apply encapsulator over that and sealant over the encapsulator. Paint over both.
But don't remove affixed sealant between the floor and kick panels. Just loose stuff, if accessable. Maybe try the gentle application of a small, flat-blade screwdriver and shop vac with crevice tool. After rust encapsulating, seal the area between the two better than before to stop water from draining inbetween the two as so often occurs. Then paint over to make all pretty.
Old 03-14-2005, 02:10 PM   #9
shifty
Questionable
shifty's Avatar
Hell yes, Eastwood's rust encapsulator stomp's POR's dick in the dirt (pardon my french).
Don't use POR products. Eastwood's stuff is not only cheaper, it rolls on smoother and cleaner, doesn't bubble, lays down flat every time and does a better job of protecting against nearby rust spots invading into the areas you've painted.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
