03-14-2005, 09:36 AM | #1 |
Instrument panel lights not working on 71GMC...
What should I do first? The interior dome light works fine, all signals work, headlights work, brights work, but no instrument panel lights, no radio. Is there a fuse that controls both? Where is it? Also, one highbeam is out, is it best to replace both together? Any tips, or is just a few screws and plug it in?
Better to get instructions now, so thanks for the help! Tom |
03-14-2005, 11:15 AM | #2 |
Yep there's probably a fuse burnt out. If you have the original radio crawl under the dash and find the red power wire and trace it back to the fuse block and find the spot where it plugs in. There should be a fuse right above the plug or to the side of it, I'm not sure.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
03-14-2005, 11:36 AM | #3 |
Check your light switch first. Turn the knob CCwise to see if they are just dimmed down. Then check here:
#1-radio #2-panel lights Head just a few screws and a spring.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-14-2005, 01:23 PM | #4 |
Where's my beer?
Mine had the headlights working fine, high and low beams, but the panel had no lights at all. It turned out to be the headlight switch. It's only a $10 part and it took longer to go to the parts store and get it than to install it, so for just $10, i'd give that a try first, assuming the fuse is good.
Pete
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
03-14-2005, 02:21 PM | #5 |
Still drivin' a Rat Rod
Mine was the swtch also.Swapped it out,and the panel lights worked.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-14-2005, 07:17 PM | #6 |
Thanks for the help, gentlemen! I'll get-r-done!!
Many thanks for the tips and detailed pictures! I think I can do this!!
