? for you 5/7 droped truck guys
could i get some of you guys to post some pics of some 5/7 droped stepside trucks with eny rims but would like to see some tork-thrust 2s (sp?) or some weld pro stars and how wide fo back rims can you put up under the back and what front rims do i need how wide back spacing etc do you need for the front with that drop so nothing will rub?
Thanx for eny help
1979 chevy c10 short bed step side BBC in the works ![]() |
you can run 9½" in the back, with 5½" of BS on a 7" drop.
#3 | |
paper or plastic?
here a pic for you http://67-72chevytrucks.com/vboard/s....php3?t=135524
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
![]() Join Date: Mar 2005
Nice truck! While you're on the subject of 5/7 drops, how much wheel and tire can you stuff under a Fleetside? I've got a 15x10 widened Rally with a 4.5 backspace with a 285/70-15 with a 6" drop, and it looks like it will be ok. The truck is in the mock-up stage, so I haven't had the opportunity to drive it yet.
________ Yamaha bruin 350 specifications Last edited by chevyrestoguy; 02-18-2011 at 10:48 AM. |
paper or plastic?
I dont know if the stepside fenders are in the same spot as the fleetsides but here is a pic of a 285/70/15 on a stock 15x8 rally
Thanx guys but are you sure you cant fit eny wider rims then 9.5 on the back like i have 15X10.5s with 275/60/15s on the back of mine and i think if i had about a 1/2 inch or so of it more on the back side it would tuck em
grande is that a true 5/7 drop? what kit did you use and what it cost? did you have to C-notch the frame or you just do it just in case? thanx
#7 | |
paper or plastic?
I dont remember what brand but I did buy it from stylin concepts though. The front has spindles and springs the rear has a flip kit/shackles and notch. If you just do the flip you should not need a notch but if you add shackles I would do the c-notch. Remember though, it may not look too low but those tires are about 30"-31" tall on the back.
