Old 03-14-2005, 11:02 PM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
uuummmmm???
i just dont get it.... i twist the distributer till the motor runs smooth... then i check it with the timing light. nothing... so i had my dad watch it with the light while i did the twisting.... the timing is retarded.... so i advanced it.... when it finally started showing up in the marks... the engine was barely running. whats goin on here?!!?!?!?!?? im tellin ya... pretty soon im gonna plead insanity
bbchevy is offline   Reply With Quote
Old 03-14-2005, 11:06 PM   #2
badone07
Project 2 Resume
badone07's Avatar
did someone change the balancer or timing cover?
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 03-14-2005, 11:07 PM   #3
andrew king
Is it a tooth off or ???? Propably not 180degrees out propably a tooth off
andrew king is offline   Reply With Quote
Old 03-14-2005, 11:21 PM   #4
bbchevy
87 Wanna Be K30
bbchevy's Avatar
ya see thats the thing... i've been messing with it for about two days. when i think i have the dist perfect... i encounter the same problem.and the backfiring is driving me NuTs! im gonna be in a white jacket by the time i get this thing done. and can someone sent me a pic of your plug wires and the numbers on em. which socket is #1. when i got the truck it had no wires on it and the chiltons i have is useless, its like one of the first chiltons ever made for these trucks. im not sure which one on the cap is #1. i set it according to how the chiltons looks and the damn thing kicks back. so i set it to how i have it and it works... HeLp Me pLeAsE!
-Scott
Old 03-14-2005, 11:21 PM   #5
Russell
Professional Grade
Russell's Avatar
Try idling it way up, then setting the timing to a ballpark figure, then idle it down a bit, and set the timing again, until you've gotten to the point that it is idling about 700 rpm, and is where you want it.
Timing will significantly affect engine idle speeds
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-14-2005, 11:25 PM   #6
bbchevy
87 Wanna Be K30
bbchevy's Avatar
when i idle it up it goes "pop ca pop pop pow pop pow" or something like that. and the "Y" pipe from the manifolds is shot so i was going to buy a new one from napa. the truck is an 86 which means it should have a 700r but it has a th350 so the cross member is back farther. should i get a y pipe for an 84 or something?
thanks
-scott
Old 03-14-2005, 11:36 PM   #7
1FaastC10
1FaastC10's Avatar
adjust the timing so that it runs smooth, and starts easy both cold and hot, and adjust the idle at the carb. NEVER use the timing to adjust idle. another good way to adjust the timing is to hook a vac gauge to a direct manifold source, and adjust it for the highest vac reading you can get. then adjust your idle. i have adjusted several this way and never had a problem.
1FaastC10 is offline   Reply With Quote
Old 03-14-2005, 11:39 PM   #8
badone07
Project 2 Resume
badone07's Avatar
not that it really matters where #1 is, as long as it's at tdc and correct firing order...
ok i crudely edited the pic. sorry would've took a pic, but there is a skunk presently under my truck that i don't want to get upset, by getting too close to it.
John
Old 03-14-2005, 11:42 PM   #9
bbchevy
87 Wanna Be K30
bbchevy's Avatar
but what about the fact that it never goes into the timing marks? should i just do it by ear and by guess and say the hell with the timing light? this is all just kinda new to me. sorry for putting you guys threw all this. im just really confused. i thought the marks were supposed to somewhat line up.then it runs good, the mark on the balancer is about an inch retarded.
-scott
Old 03-14-2005, 11:43 PM   #10
bbchevy
87 Wanna Be K30
bbchevy's Avatar
yea thats the same diagram as... well actually it looks like you scanned the chiltons lol. but yea i wish they showed the coil thingy on the top of the dist.
Old 03-14-2005, 11:44 PM   #11
badone07
Project 2 Resume
badone07's Avatar
that's why i asked if someone switched the balancer or timing chain cover. which sounds exactly what your problem is. where is the tab positioned right now, directly under the water pump (12 o'clock) or towards the drivers side (like 1 o'clock)?
John
Old 03-14-2005, 11:47 PM   #12
bbchevy
87 Wanna Be K30
bbchevy's Avatar
the tab is more toward the drivers side...
-scott
Old 03-14-2005, 11:49 PM   #13
bbchevy
87 Wanna Be K30
bbchevy's Avatar
i just dont know if the balancer or timing chain cover have been touched... this is the way i got it. there seem to be alot of unknowns with this motor. im basically starting from scratch. i bought it not running but supposedly it ran prior to my purchasing it. it also sat for about a year before i bought it.
Old 03-14-2005, 11:50 PM   #14
bbchevy
87 Wanna Be K30
bbchevy's Avatar
oh and the motor had an edel intake and carb. so the dist has to have been taken out in the past.
Old 03-15-2005, 12:10 AM   #15
badone07
Project 2 Resume
badone07's Avatar
i edited the pic above. might as well start from scratch.
might be best to just turn over motor by hand to tdc. then pop off the cap and see where rotor is pointing. sounds like maybe the wires are not positioned right. maybe prior owner just dropped distributor and rotated wires.
ok, also assuming the vacuum advance is disconnected and the motor is idling at about 700 rpms when trying to time it. there are a couple of things it could be, the outter ring of the balancer could've also spun. no such thing as a "tooth off" with a distributor drop, other than the vacuumm advance hitting the firewall or intake. the timing chain would have to be off a tooth.
John
Old 03-15-2005, 12:21 AM   #16
piecesparts
Parts and more parts
piecesparts's Avatar
Let's go to the basics of this issue---- Take the motor to TDC on the #1 cylinder (this is with the intake and exhaust valves closed), check the timing marks on the harmonic dampener (should be at TDC or "0"), now look at the distributor rotor (it should be oriented at the #1 spark plug wire--if not then the distributor may need to be rotated a tooth). If the dampener is not at TDC, then change it out for another one.
Old 03-15-2005, 12:30 AM   #17
bbchevy
87 Wanna Be K30
bbchevy's Avatar
ok, ill try what you guys have told me tomarrow and ill update you on the status as i go. but real quick, i bought the y pipe from napa. the one for the 86 700r. im bringing it back tomarrow because it hits the crossmember. what year should i get a y pipe for instead? thanks alot by the way guys. sorry if my idiot mind has driven you guys insane.
-scott
Old 03-15-2005, 12:31 AM   #18
bbchevy
87 Wanna Be K30
bbchevy's Avatar
btw the truck has a th350 in it now
thanks
Old 03-15-2005, 10:39 AM   #19
1986Silverado
What I drive
1986Silverado's Avatar
-scott
Tell them it has a th-350. Mine is an '86 also and came with the TH-350 from the factory. So they did come with the TH-350 in '86.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 03-15-2005, 11:36 AM   #20
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Yep. Mine came with a TH350 from the factory as well.
Slonaker
EDIT: This might help you get everything straightened out with the distributor if it was installed incorrectly:
http://www.73-87.com/7387garage/drivetrain/disremov.htm
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-15-2005, 03:56 PM   #21
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Maybe the balancer has slipped? Those are TH350c's (lockup torque convertors).
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-16-2005, 12:03 AM   #22
bbchevy
87 Wanna Be K30
bbchevy's Avatar
ok, so i put exhaust on the truck today and new plugs. for some reason when the truck is cold( i shut the choke off) it seems to run the best. i can almost actually drive it down the road... but when it warms up all i hear from the exhaust if popping and backfiring and it backfires real loud when i go to take off. so i lack bottom and top end... and i suck at this whole timing thing. and i have no money to have someone else do it for me. and im wasting money with insurance because its on the road and i havent been able to drive it for about two weeks. AAAHHH im cant take it.
Old 03-16-2005, 12:05 AM   #23
bbchevy
87 Wanna Be K30
bbchevy's Avatar
oh and to top it all off... it shifts real quick through the gears so by about 15 mph its in 3rd. does that have to do with the detent cable at the carb? and how do i fix it.
thanks alot for all your help guys!
-Scott
Old 03-18-2005, 10:03 AM   #24
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
Not to insult your intellegence but are you disconnecting the vaccum advance before trying to set the timing.
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 03-18-2005, 01:24 PM   #25
Ric83
Ric83's Avatar
My buddy's truck was doing that. We ended up just adjusting the card and timing by ear and forgot about the timing gun. It ran really well afterwards. Never did figure out why it was doing it either.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
