Old 03-16-2005, 01:10 AM   #1
skokie
skokie's Avatar
Metal Fuel Line WIth Filter
Does anyone know if it is possible to get a screw in metal line from your qjet to a external fuel filter? I thought I saw one on a engine pic posted up here. I will see if I can locate the pic.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-16-2005, 01:40 AM   #2
skokie
skokie's Avatar
Ok found the pic..
68 build thread
Old 03-16-2005, 02:34 AM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
thats a qjet carb ?
i like the fuel filter and line though
never seen one like that
tnblazerk5 is offline   Reply With Quote
Old 03-16-2005, 02:52 AM   #4
skokie
skokie's Avatar
I think that the carb is a edelbrock.
68 build thread
Old 03-16-2005, 07:19 AM   #5
Sonny
Active Member
Summit has those. EDL-8131 or EDL-8134
http://store.summitracing.com/partde...0&autoview=sku
Sonny is offline   Reply With Quote
Old 03-17-2005, 12:09 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
not only can you do it..but you should. That is the best place to install it.
Old 03-17-2005, 12:23 AM   #7
skokie
skokie's Avatar
But the question is can you put on a qjet?
68 build thread
Old 03-17-2005, 07:06 AM   #8
Longhorn Man
a fuel line is a fuel line....don't matter if it is hooked to a q jet a edelbrock or a toro sprinkler....
Old 03-17-2005, 07:09 AM   #9
Sonny
Active Member
Q-jets and EPS carbs are basically the same.
Old 03-17-2005, 08:53 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Brad, you're going to have to bend and flare the lines yourself to get that setup on a quadrajet.
What's wrong with the stock fuel filter in the quadrajet?
I always run them, along with an inline under the truck between the tank and the framerail. That gives you one before the pump and one before the carb.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-17-2005, 12:23 PM   #11
skokie
skokie's Avatar
Kevin,
Nothings wrong with the stock fuel filter. Just curious.
68 build thread
