Old 03-19-2005, 02:59 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
for the 100th time
I know this has been asked a 100 times. how do you set the tv cable on a 350? I went here (http://www.73-87.com/7387garage/drivetrain/detent.htm ) but didn't know where the "screw" was? to my memory I've never heard the trans go down to 2nd when passing someone. but then again I don't think I've ever gone wot so thats probably my problem. is it supposed to go down to 2nd when going up a steep hill? I believe I have (according to the sticker in the glove box) 3.73 rear with stock wheels *or the equivalent for today*. and I am hopeing to atleast top off the diff sometime soon and want to know what kind of oil and how much? thank you for your help. matt
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 03-19-2005, 11:44 AM   #2
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
mat you need to adjust the cable which is only a kick down cable on a 350. with the cable hooked up engine off go to max throttle your tranny cable should max out the same time as your max throttle. adjust accordingly. Your rear end should have 80-90 gear oil in it. If you also have a posi unit you may also need to add limited slip oil to the rear end gear oil.
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 03-19-2005, 05:37 PM   #3
Lynx
Lynx's Avatar
If you have never felt your tranny kick down you definatly have problems. Either that or you drive like a granny
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
