07-22-2002, 04:20 PM | #1 |
Saving 1 truck at a time!
Remove Spindle - Help?
Do I need that special "ball joint removal" tool to remove the spindle from the upper and lower "A" arms? I thought they just popped off with a little tap from a BFH once the nuts were off!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
07-22-2002, 05:40 PM | #2 |
It really helps to have a pickle fork. Sometimes it takes some heavy pounding even with them. They don't cost too much, less than $10. Good luck!
Ben
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
07-22-2002, 10:57 PM | #3 |
SLICER AND DICIER
But be carefult they tear the boots up then you gotta replace the ball joints. But if you got it apart you should do it anyway they are not that expensive, and worth doing now. I always use the BFH, and beat the hell outa it. hehe
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
07-23-2002, 09:38 PM | #4 |
Ya usually they come off easy, but sometimes they absolutely will not come off without a pickle fork. 90% of the time i just sticka pry bar in there (or leave a light load on the springs) then hit the spindle.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
