Old 03-12-2005, 10:46 PM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Those with fuel cells under bed, I need help with mounting it.
I have the Summit Racing fuel cell that I want to mount between the rails at the rear underside of the box. The question I have is regarding how to mount it. It came with 2 U straps that go around it. Now what I need to know is if I need to mount it so that it sits flush with the top of the frame, or like I seen in a picture, sitting slightly higher than the frame.
But the problem I can see coming is with the box crossmember that goes across right above it. I think it might hit the fuel filler neck that is stiking up right there.
Any pics, advise, help appreciated!
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 03-13-2005, 11:08 AM   #2
REPO1
Shortbox wanna-be.
REPO1's Avatar
Anyone?
Old 03-13-2005, 12:09 PM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
fraid I'm not of much help here cuz I haven't made it that far but I'm interested in finding out too.
ttt
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-13-2005, 12:35 PM   #4
XXL
Seņor Member
XXL's Avatar
The bed xmember that runs across the top has to go. Straps typically run side to side with J-bolts on the left side rail and regular ones on the right (or did I get those two backward?).
XXL is offline   Reply With Quote
Old 03-13-2005, 01:51 PM   #5
bigblock73
yeller
bigblock73's Avatar
While I know 67-72's are different than 73-87's, here is the article I wrote when I did the same thing in my '73. Maybe it will help a little.
http://www.73-87.com/7387garage/chas...ellinstall.htm
bigblock73 is offline   Reply With Quote
Old 03-13-2005, 02:00 PM   #6
Spoof
Spoof's Avatar
I removed a crossmember on my frame, I think most folks do? I'll look for a pic and can take more if you need.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-13-2005, 07:29 PM   #7
72MARIO
72MARIO's Avatar
Spooof,
Have you noticed how much you have to hack out of you bed crossmember ? It made me so sick to sent the tank back.
I bought a 20 gallon 24x20x10 Fuel Cell from Triangle Eng. with a 0-90 ohm sending unit. I will mount it next weekend I was planning on using stainless straps 1/8" x 2" mabye 1 1/2" wide and bolt them to the frame and mounting pads on the cell. I will post pics when I get it finished.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-13-2005, 08:34 PM   #8
Russell
Professional Grade
Russell's Avatar
It doesn't affect the strength of that bed that much!
I cut the crossmember on my 80 GMC's bed, and since it was super rusty, I simply jumped on it to test the strength of the floor, and my 195 lb self jumping directly onto the center of the cut crossmember did nothing to the bed.
If you were really concerned about it, get an I-bar of metal of the right height, slip it into there, weld it up, then seal r' up to protect against rust.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-20-2005, 10:10 AM   #9
REPO1
Shortbox wanna-be.
REPO1's Avatar
Originally Posted by 72MARIO
I bought a 20 gallon 24x20x10 Fuel Cell from Triangle Eng. with a 0-90 ohm sending unit. I will mount it next weekend. I will post pics when I get it finished.
Hey Mario,
Did you get this install done?
As for mounting the fuel cell, my straps will be going from front to rear, not side to side. I'm talking an actual fuel cell, not a blazer tank.
Here is a picture from somebody's truck. (not mine) But notice how close far he mounted it above the frame rails? I assume this is because it looks like he is planning on having a door in the bottom of the bed. I will be using a hose to the center of the cell. So I guess it just needs to be enough to clear the hose.
Old 03-20-2005, 11:58 AM   #10
lost wages
lost wages's Avatar
the last pic of the cell is raised so it doesnt rub the street being as the truck has air bags. i also had to raise mine.
lost wages is offline   Reply With Quote
Old 03-20-2005, 01:01 PM   #11
REPO1
Shortbox wanna-be.
REPO1's Avatar
Lost Wages,
So you raised it from what you have in the picture? What method of fuel filler do you have? I was hoping for the side marker light fill.
Old 03-20-2005, 01:39 PM   #12
72MARIO
72MARIO's Avatar
I did not end up getting the cell mounted yet. I forgot it was march break and my Girlfriend was home from school so All I made time to for was rebuild the tilt coloum. I will get the cell mounted this weekend. Hopefully..... I know it's Easter but I should be able to fit it in. I did a bit more thinking. I decided to run the straps from front to back. I just had not about mounting another crossmember behind the axel to mount the front of the straps to. My truck is a leaf truck and there is only one crossmember and it's at the back.
We will need to mount the cell flush with the top of the frame unless you are cutting the bed floor out.
2005 TAHOE DD
Old 03-20-2005, 02:45 PM   #13
72MARIO
72MARIO's Avatar
I am thinking of what lost wages did to his truck. I like that style I tthink that's the way to go.
2005 TAHOE DD
Old 03-20-2005, 03:19 PM   #14
REPO1
Shortbox wanna-be.
REPO1's Avatar
His fuel cell looks identical to mine. That is how I planned on mounting it. But I wasn't sure how high I could go with it. I don't have a bed for the truck yet, so I was hoping someone could measure and tell me for sure.
Reid
Old 03-20-2005, 07:55 PM   #15
72MARIO
72MARIO's Avatar
You have to keep the fuel cell level or below the top of the frame. The bed crossmember sits right on top. If you put the tank higher than the frame you will need to notch the bed crossmember.(or floor)
2005 TAHOE DD
Old 03-20-2005, 07:56 PM   #16
72MARIO
72MARIO's Avatar
How many gallon tank did you get ? and what's the size of it ?
2005 TAHOE DD
Old 03-21-2005, 05:35 AM   #17
lost wages
lost wages's Avatar
on mine i just cut the bed floor out, its got a trap door on a hinge to get to the filler. In the first pic of mine the bed lays on it, i raised it around 8 inches.
Old 03-21-2005, 07:14 PM   #18
72MARIO
72MARIO's Avatar
Wow that nice.
Looks like you have a ton of hours into that box.
2005 TAHOE DD
Old 03-21-2005, 07:21 PM   #19
vfrdude
vfrdude's Avatar
Hey Mario,
Those upper shock mounts are going to get in the way of something, don't you think????
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
