Old 03-22-2005, 02:09 AM   #1
TUFF ENUFF II
hub swap
i have a six lug bolt pattern dana 44 can it be converted to a 8 lug pattern ? what is needed and what is different?
TUFF ENUFF II is offline   Reply With Quote
Old 03-22-2005, 07:06 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The easy way: find an entire 8 lug axle and swap axles. Of course you have to make sure you match the rear gears. Second easiest, still find an 8 lug axle and swap steering knuckles out. The axles will be the same. Or I believe you can swap backing plates/spindles and hubs. Still need to find the parts or donor axle though.
Good info:http://77cj.littlekeylime.com/flatop_knucles.html
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-22-2005, 11:01 AM   #3
nu2-72
Jim is correct. I have a 1/2 and 3/4 side by side. The spindles are the same in every detail except the bearing sizes. Same 6 bolt mount, same length and 4 lug retaining nuts. Just bigger diameter for the bearings for the 3/4 hub.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
