03-22-2005, 10:30 AM | #1 |
anbonther question on lift
I have an 88 Gmc burb. it has leaf springs on front. I want to eliminate blocks on front lift, I'm looking at add a leaf. but they only go to 87. will they work ?
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
03-23-2005, 08:19 PM | #2 |
Truckless for the moment...
Yes, they will, as long as they're the same width as your stock ones. I'm pretty sure 87-91 was the same regarding springs. Also check into Off Road Design, they make a zero rate that will raise the front about an inch, however it won't firm up the spring rate. It's basically a steel block, but they're safe to use on the front because they're bolted into the leaf pack with a new bolt/pin. I have them on the rear of my truck, and have had no problems with them.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now... |
