Until Seventy Times Seven
As I mentioned in a previous post, I replaced my 6-port fuel valve. It also had a 'very' slight leak on one of the riveted seams on the valve (when running on one of the tanks). At high throttle, I had fuel delivery problems similar to a bad fuel pump. I suspect that air was entering the fuel line at the seam. Fuel pump was $65 to replace with a AC/Delco.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
| Bookmarks |
