![]() Join Date: Mar 2004
kick panel to kick panel measurment? 64-66
hey guy's i'm trying to plan a mod for my truck and i need the distance from the drivers side kick panel to the passenger side kick panel right under the dash. if you could help me out with this please let me know. i don't own a 64-66 so i can't just go measure mine. the short story is i want to put the 64-66 dash in my 71.
thanks, ondrew |
be aware that the 60-66 dashes are well spot welded in at the front.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
yea i figured it's spot welded in the window lip. got a measurment? please please please
63.75"
thank you, thank you, thank you, thank you, thank you, thank you, thank you,
ondrew |
I was told once it's something like 20-30 somethign odd spot welds holding it on... the '64-66 dash that is...
-W |
i would assume that it's real simular to the 67-72 which is held on by the 20-30 spot welds and 4 bolts that go into the upper kickpanel areas.
ondrew p.s. if they are interchangable i will deffinitly let you all know . |
