03-24-2005, 12:44 AM | #1 |
Bowtie (yellow) on my horn button? And seatbelt insert?
I'm sure its the original horn button (ie. not a replacement), but all I can find are blue bowtie replacements. Did 69 have yellow and 70 have blue? Also With seatbelts (lap) I found blue "GM MARK OF EXCELLENCE" buttons (the inserts that you push to release the latch) but I swore I saw them in yellow in the past also, does anyone have info on this? I could be confuseing the seatbelt inserts with the Chevelle, Camero, Nova ones......???? Doug
03-24-2005, 04:40 PM | #2 |
TTT Anyone?
03-24-2005, 04:49 PM | #3 |
All I have ever seen for the seat belt inserts for that year truck are the blue ones that you mentioned. I am pretty sure about this one.
All I can remember for the steering wheel is blue as well but I am not to sure about this one. Anyone Else???
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
03-24-2005, 04:59 PM | #4 |
Resident Curmudgeon
I have seen the gold bowtie horn button. I think it's from 73-up vans that still used the 69-72 truck style wheel. In 73 all bowties for trucks/vans went from blue to gold and I'd assume if you needed a replacement horn button after 72 you got a gold one. It's a theory anyway
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-25-2005, 06:05 AM | #5 |
OK, that helps. I find these little bits of info interesting. Thanks
