Old 03-23-2005, 10:55 PM   #1
66gmc
a few questions from me, the uninformed
1. i have a 66 gmc its a 1500, is that a 3/4 ton or 1/2ton ?
2. does the 1/2 ton have 8 lug on the rear?
thanks in advance. TONE
66gmc is offline   Reply With Quote
Old 03-23-2005, 11:14 PM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
The 1500 is a 3/4 ton.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 03-23-2005, 11:19 PM   #3
66gmc
one more....what is everybodys top speed in there truck i get through 1-4 so fast cause 1 is total granny when i get to 4 i'm at 50 and 65-70 is topped out. just curiuos what yr you have and what the top speed is.?
Old 03-24-2005, 04:04 AM   #4
Chevyboy1962
C10 now is a GMC
I'm currently running the original 235 I6 backed by a 3 speed on the floor, with 3:90 gear ratio 10 bolt eaton posi. On the freeway(or on back roads) she flys along at 65-70mph at about 2,800-3,000rpm's. She responds pretty well, and wants to go even faster, but I don't want to push it anymore than 3,500rpm's while on the freeway. Soon to be changing I6 & 3 speed out for a sbc350/th350 combo for more reliability, and for long runs.
David
Old 03-24-2005, 05:30 PM   #5
a66c20
a66c20's Avatar
I have a Chevy '66 C20, which is a 3/4 ton, it has 8 lugs all the way around. It also has a 4.10 rear gear - no fun on the freeway , but awesome around town. I plan on going with an overdrive in the future.
Gary
1966 C20 - Factory 327 with Edelbrock RPM heads and manifold, TH400, 4.10 rear gear
1970 Factory 455 GTO - #'s matching, 1 of 1986 produced
a66c20 is offline   Reply With Quote
Old 03-24-2005, 06:15 PM   #6
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
not to sure what my gear ratio is, but i have a 305 v6 w/ sm-420 my top speed is about 65-70.
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 03-25-2005, 11:56 AM   #7
newbe351
I have a "66 with the 351 V6, sm-420 and 3:54's. Just put 31" tires on it which helps, but I run it at 2500 on the freeway which is about 65 mph.
newbe351 is offline   Reply With Quote
Old 03-26-2005, 09:21 PM   #8
66gmc
thanks guys thats what i was looking for.
