Old 03-28-2005, 11:06 AM   #1
saxmo
saxmo's Avatar
Teflon tape..yes or no?
Does anyone use teflon tape on their brake, and tranny connections?
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline   Reply With Quote
Old 03-28-2005, 11:13 AM   #2
kwmech
NO! that's what the double flare is for.
Old 03-28-2005, 11:49 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
exactly
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 03-28-2005, 12:13 PM   #4
cdowns
cdowns's Avatar
works good in kitchen and bathroom , cars not
Old 03-28-2005, 01:23 PM   #5
ddsmith
Glowing since 1978
ddsmith's Avatar
Teflon tape is a good thing on pipe threaded fittings. Stuff like water pump pipe nipples and intake pipe nipples are fine. The compression fitting is what is suppose to seal the hard line connections. Not the threads. If a compression fitting won't seal it needs to be replaced. They are not good for life so to speak. Each time they are taken apart they need tightened a little more to get a seal. Eventually, they won't seal correctly no matter how tight you make them.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 03-28-2005, 01:24 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
anything that has pipe threads. Like the fitting that screws into the water pump for the heater hoze hook-up. Or the oil pressure line hook up at the back of the block.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-28-2005, 01:31 PM   #7
saxmo
saxmo's Avatar
kewl... was just wonderin'
Old 03-28-2005, 06:33 PM   #8
PMS
If it makes you feel better you can use teflon paste on the threads. Similar to tape in that it seals threads. Since it is a paste not a tape, no strings can travel.
PMS is offline   Reply With Quote
Old 03-28-2005, 09:12 PM   #9
franko72
Franko72
franko72's Avatar
teflon paste or tape will make turning those threads easier when you make them up.I put teflon on all tapered threads and sometimes on flare fittings just to make the thread glide easier.Teflon is not a sealant, only a lubricant to help a tapered thread reach its make up home.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 03-28-2005, 09:30 PM   #10
Sweet72
Sweet72's Avatar
Teflon tape is a wonderful thing, and as franko72 says it makes turning threads easier... in fact so easy that when I was installing the pipe thread brass cooler line fittings into a aluminum transmission case they went in so F___ing easy that I cracked the case (you can only imagine the expletives streaming from my garage that day) so be judicial when torquing fittings when using this stuff.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-28-2005, 09:38 PM   #11
Shane
Shane's Avatar
Franko is correct, or at least that is what i have been taught as well, that Teflon tape is for lubricity and NOT sealing purposes.
Shane is offline   Reply With Quote
Old 03-29-2005, 04:57 AM   #12
Americanrider
"lubricity" ......they didn't use words like that where I come from....LOL
Telfon tape? always!
Americanrider is offline   Reply With Quote
